External sat card | |
| | #3 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. |
Yes, is the simple answer to that, Pentamedia do one, but i think it is data only. There are others made, i saw them at this years trade show, but I don't know who sells them. try www.pentamedia.com , or www.strongsat.com, i think you'll find that most of the USB modules are data only. Rolf
__________________ | |||
| Long Term Contributor Join Date: 01-05-1999 Location: scotland
i have the internal pentamedia card but did not see any external cards when i was shopping around but if you think you seen it at the trade show then it will probably be in the shops soon if not already. I fitted my own card internal without any significant problems but i like external modems. Does it have to be an external card? do you have a lack of ports in your motherboard? i have about one slot left on my motherboard, its amazing how they go. | ||
| | #6 | |||
Hi stock, The PC sat cards are not particlarly good for dish alignment, as they react too slowly, you're better off with a £30 analogue meter, which will get you onto the Satellite with a reasonable degree of accuracy. The USB sat cards by the way, can be bought from Digi-Cams UK on 020 887 80194 but I think they are only data cards. Did you get any luck through the web addresses?
| | #7 | |||
http://www.digicams-uk.com/category14_1.htm Above is the link to the DigiCams site and specifically the USB receiver. Hope this is of help. Rolf
Similar Threads | ||||
| MR 1.04 & NOVA card (IRD2) & Manhattan 3300 | Arkadian | Matrix Reloaded, Revolutions and CAS interface | 20 | 08-05-2004 02:59 AM |
| Seca2 card for 140 euro is a fraud | net1 | Seca/Mediaguard system | 0 | 28-10-2003 06:23 PM |
| Which DVB card? | alnitak | Satellite PC Card Systems & Internet by Satellite | 4 | 26-08-2003 02:17 PM |
| Pentamedia card not initializing | s*t*a*r*m*a*n | Computer Discussion | 1 | 14-07-2003 05:07 AM |
| new card don't work | Robbiewright | Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 3 | 25-06-2003 09:05 PM |
