multi satellite card in one pc | |
| Member Join Date: 05-01-2009 Location: cairo egypt
My System: twinhan card |
hello every one,,, i have four satellite cards,,,3 twinhan and one technisat,, is it possible to all of them to work in the same time...i mean in one pc? i need to capture from the 4 cards in the same time and if so..is there any software that can run multiple time like virtualdub but for satellite cards,,,? | ||
| | #2 | |||
Welcome to the forum mgm21m
My System: twinhan card | thanks topper,,,anyway i have two processors zeon and the processing is not important all i need is a software with multiple copy,,,like virtual dub ...software can open more than one time,,,is there any software can open more than one time??? | ||
Blog Entries: 4 My System: Sky+, DB 7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | I would also have serious doubt as to whether the pc will be capable of powering 4 LNBs. | ||
| | #5 | ||
| Specialist Contributor Join Date: 05-04-2005 Location: Midlands UK
My System: Skymaster DCI9900 + PC/twinhan combination. 80cm dish. GBPVR with 2 DTTV cards +hauppauge Media MVP | Not sure that processing power would be an issue if recording FTA channels....I have 1 x DVB-S and 2 x DVB-T and can record 3 programmes simultaneously on a 2.8GHz P4. Power requirements for the LNBs may be an issue, but presumably that could be overcome using a quattro with a powered switch (assuming all channels from the same sat)? | ||
| | #6 | ||
| Regular Member Join Date: 18-10-2005 Location: BE
My System: Twin monoblock and twin LNB on 80cm transparant dish rigged for twin reception from HB Astra 1 and 2 + TopField TF 7700 HDPVR + TwinHan VisionDTV | When just recording the processing requirements should not be that high. Most of the processing requirements for an HTPC are for the MPEG2/4 decoding and that's only needed when viewing. I/O bandwith might become an issue at some time, especially if all those streams are sharing the PCI bus. So the more of those tuners are PCI Express, the less issues you can expect. You might want to have a look at mythtv. You could try to set up your box with 4 tuners as master and run different clients when you want to view. | ||
| | #7 | ||
My System: Skymaster DCI9900 + PC/twinhan combination. 80cm dish. GBPVR with 2 DTTV cards +hauppauge Media MVP | Or if you are more Windows orientated; take a look at GBPVR | ||
| card, multi, satellite |
