yanksee encrypte 100% ?
Thread Tools Display Modes
Old 17-07-2004   #1
Exclamation yanksee encrypte 100% ?
hello, I installed mytheatre and yanksee with my satellite card Hauppauge directed towards hotbird but I cannot see SOME crypted channels like MTV...
Can any body help me ?
thanx !
mc_magic is offline   Reply With Quote
Old 17-07-2004   #2
Hi.
Yankse can decrypt almost all encrypted channels, but it doesn't work with Sky Italia (Seca 2).
Be sure to have latest softcam.key.
Bye
Zanza is offline   Reply With Quote
Old 17-07-2004   #3
thank you so much for reply,
i had the last version of softcam.key but it doesn't work with some channels ! i can show multivision 1-2-3-4-5-6-7 for exemple but i can't show mtv2pop or mtv hit ... or some others crypted channels, please i have another question, can i use yanksee with prog provided by hauppauge nexus, the last version 2.17 ?
waiting for ur replays
Old 17-07-2004   #4
kalamar
Posts: n/a
Talking here is one reply for you.
DVB tv&radio is what usually is supplied with Nexus-S
The program provided with thw Hauppauge dont use the MDwrapper so no MDplugins , best is use MyTheatre 2.76 or the latest versions of ProgDVB.
Old 17-07-2004   #5
thanx kalamar !
Old 18-07-2004   #6
T_G
The Consumate Dreamer
T_G's Avatar
Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything.
Muhuhuhahahahahaaaaarrrgggh
I have not been using my SS2 for a while (been playing with the Dreambox), but is this true that even though Sly Kitaly is working on the Dreambox it is not possible to watch it on PC based cards??
__________________
I only believe stuff that comes straight from Mr. Horses mouth
T_G is offline   Reply With Quote
Old 19-07-2004   #7
BGonaSTICK's Avatar
The latest version of Y*nkse (V1.31.0) has not been modded for the latest nano changes (see wvvw.y*nkse.com).
Though this may seem a bummer, fear not as good news is never far behind.
Pick up the latest version (V1.0.4.0) of a plugin called S2emu.dll from TCD and other good places.
Now don't get me wrong, I'm Vlinders biggest fan, but during my day-long testing of it, it rocks. I've replaced Y* with it for now.
The hash and mask tables are hard-coded into the .dll, so you don't need anything other than the .dll and the s*ftcam.key file (which you should put in the root dir, not the MDPlugins dir). Very neat and tidy.
Stability is better, channel switching times are faster, and it seems to be getting updated regularly.
It also does C*nax, and other stuff....
Here's the readme :-
S2emu v1.04
v 1.04
Added Conax.
Fixed Nagra autoupdate on Hispasat channels and fixed MECM algo for TvCabo.
Autoselecting of ECM pids.
Enable/disable of module (Check menu).
Auto selecting pid on FullX channels(no need to add ECM pid 03EB).
Tested with ALT-DVB, My Theatre and ProgDVB(with SkyStar2 card).
v 1.03
Very fast Nagra autoupdate(tested only on Polsat).Keys are saved directly in SoftCam.
If it fails to save keys, use Info window and enter key manually in SoftCam.
Note: Use complete rescan of chanels, and if some program don't work select ECM Pid manually.
Where possible in DVB programms set Packet Size to 184.
Put file "SoftCam.key" in root dir of DVB programm.
v 1.02
Added Nagra (tested on Polsat). Please report if it works with other providers.
No more FreeX, they changed algo.
v 1.01
Less freezing on SHL.
FreeX works only on Hotbird Transponder:12207,Pol: H, Symbol: 27500.
v1.00
Tested in ALT-DVB. Working S*ca,S*ca2,VIACCESS and SHL.
For FullX add ECM Pid= 1003(Hex:03EB) and CAID to 0000 or 1FFF.
For now hash and mask tables are in .dll.
Best regards from Croatia.
Many thanks to Italian friends from digitalfreesat !!!
Post your comments on "www.dvbs*ft.net".
MarS
Old 19-07-2004   #8
T_G
T_G's Avatar
Hey BGonaSTICK
Now this is what I call a reply! Well done!
*Hands over BGonaSTICK the "TG's Plain English / Useful Answer of the Week Award" medal*
Cheers, I will try it out tonight!
TG
__________________
Old 19-07-2004   #9
BGonaSTICK's Avatar
Hey BGonaSTICK
TG
Humbly received...
Old 19-07-2004   #10
rolfw's Avatar
Hey you two, get a room.
__________________
Rolf
Donate
Old 19-07-2004   #11
kalamar
Posts: n/a
Angry Glad it does you some good,its not for me (yet)
I have tested it with my situation and am sorry to say it dont work for me
However if it will just update the softcam.key file with new keys it may be the answer to the new version of Yankse not doing that.
When used by itself,nothing gets decrypted,then I turn on Yankse and all is fine again. I have tried about 5 different softcam.key files and also tried some mods on them and no go fer me.
And I have noticed that the external MECM data it seems, is required for Nagra decryption,so it may be a good replacement for Fenrir should the need happen.
but its something to play with on rainy days (today!)
Old 19-07-2004   #12
please tell me if I can recieve pay channels without subscribing I have Nextwave dx 600 reciever with available cam such as via, nagra, conax etc. How can I edit my recievers key with remote. PLZ help me
yash is offline   Reply With Quote
Old 19-07-2004   #13
T_G
T_G's Avatar
Well, I did go into a room just now as you suggested. When I opened the door I saw you and Chanelhopper do some unspeakable things in there to some poor viewing card and I ran and ran and took 20 cold showers trying to wash away the horror
__________________
Old 22-07-2004   #14
BGonaSTICK's Avatar
... but did you get S2emu working?
Old 23-07-2004   #15
T_G
T_G's Avatar
Not yet, Im busy with my 1.2 m dish. Fist I'll get this up, then play with
yaks Italia.
__________________
Old 23-07-2004   #16
hey guys,
I have a problem with s2emu and MyTheatre 3.19RC1.taht thing doesn´t work.I tested version 1.03 ,1.04 and 1.05 with Mythetre 2.96 ,3.12 and 3.19 and nothing.I´m using a Typhoon DVB-s card ci (Twinhan or VisionPlus),winxp pro,pentium IV 1.5ghz.with Progdvb is everything allright but not with mytheatre.even the name "s2emu" doesn´t appears in plugins menu...please help
erni-berni3 is offline   Reply With Quote
Old 24-07-2004   #17
BGonaSTICK's Avatar
Frankly, those versions of MT are recognised as being unstable at best.
IMHO, I would go back to MT V2.76 (the last free version), generally accepted as being the most reliable, and which I personally know to work with this plugin (although not with your card).
If you go this route, be really sure to uninstall all other versions, and manually scan for, and delete any components not cleanly uninstalled. Especially files in Windows/system32. Also remove all other plugins with a similar function.
STICK
__________________
Forum Jump
