I`ve Sky Star2 Card | |
| Regular Member Join Date: 29-07-2004 Location: Milton Keynes
CAN I USE THIS WITH IT Un wanted motorised 80cm Super Jack two satellite dish with LNB, complete with Pace Mss 500 Receiver Decoder with Positioner plus Pace D55, D2 Mac Decoder (no card). If i put a new lnb can i use it with the sky star card. bas | ||
| Member Join Date: 18-08-2004
| Yes you can by putting digital lnb on it. dependent on which part of the country you live in you can actually your setup should be good enough. If you live in south they reccommend 80 cm dish if you live in the north they recommend 1m dish. Another tip use progdvb, skyview or my theatre as they already diseq plugin for skystar 2. let me know if you need more help as I currently have had my skystar 2 for 2 years | ||
| | #3 | |||
BAS | |||
| | #4 | |||
| Super Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 |
For the latter, you would also need to add something like a VBOX. STICK
__________________ | |||
| | #5 | |||
| Regular Member Join Date: 28-08-2004
The motor just does not seem to respond to any comands that I am sending from the Mytheatre plugin. That said I do not understand what all the references to "simple" and "Pos A" mean. Please could somebody confirm that the SS2 card supports the Stab HH90 motor. If so, what do I need to click on to get it to move ? I have also searched for a simple diagnostic program that would exercise the motor in some way but have not found anything. Ideally I would like to use the motor in USALS mode via the SS2 card but I would settle for a reaction to DiseqC 1.2 at this stage. TIA Richard. P.S. I am V. new to all this stuff but V. pleased with what I have seen so far. | |||
| | #6 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Have your set up the DiseqC plugin options to include your coordinates? The DiseqC setting in ProgDVB should be none.
| | #7 | |||
I am a bit confused by your question. This is what I have just done. ProgDVB | Settings | DiSEqC have now set that to "none" Installed and opened the kvaDiseqc plugin could not see anywhere to enter my coordinates tried clicking onto various button such as Go West etc but get no reaction from motor. btw I am receiving video/audio with the motor in circuit so I know that all the connections up to the Dish are valid. Do I need a specific version of the ss2 device driver ? Rgds Richard | |||
| | #8 | ||
My System: Dreambox 7000, Skystar2 | Don't know what plugin you're using, but everyone I know uses this one, which works fine and has somewhere to punch in your long/lat! Search out the item called 'DISEqC plugin SS2 V1.7' here :- http://www.skystar.rs.ba/programi.html Read the readme. You need to replace your driver manually in windows/system32. STICK
| | #9 | |||
14:35 Update: All sorted, motor now reacting to commands from the plugin, thanks again for the support. I was becoming convinced that the motor had failed.Richard Last edited by bobnuts1; 10-09-2004 at 03:35 PM | |||
Similar Threads | ||||
| Two digiboxes with one single LNB or frequent removal of viewing card? | Helmut05 | Multi-receiver/TV systems | 9 | 23-05-2005 11:07 PM |
| Sky's reponse to FTA cards. | net1 | B Sky B Digital and 28.2 East General | 21 | 23-12-2004 02:09 PM |
| Sky Remote No Work! | homerjay | B Sky B Digital and 28.2 East General | 6 | 18-11-2003 10:19 PM |
| My Solus Card sent by Sky Subscriber Services Ltd not Channel 4!! | Shahid | B Sky B Digital and 28.2 East General | 1 | 13-11-2003 10:47 PM |
| Sky to rebrand Movie channels. | net1 | B Sky B Digital and 28.2 East General | 0 | 02-10-2003 02:46 PM |
