Sky Star 2 USB *** HELP please
Thread Tools Display Modes
Old 26-08-2004   #1
My System: Illusion M3
Question Sky Star 2 USB *** HELP please
I'm using sky star usb with a laptop and progDVB to watch tv channels.
My dish as two LNBs pointing to Astra, Hotbird and Hispasat.
I can see the free channels available in Astra with progDVB.
When I choose TV Cabo channels (Portugal) I get the information that signal quality is about 60% (+/- 1%) but can get no image and sound at all.
I think the scrambled channels are not being decoded at all, although I have Yankse and snitch decoders installed with progDVB.
Do you know of any incompatibility with SS2 USB and scrambled/codified channels?
How can I get to watch those channels from CaboTV, Via+, etc..? As I said, I get the signal quality for each channel but no real image and sound...
Many Thanks.
nmigreja is offline   Reply With Quote
Old 26-08-2004   #2
rolfw's Avatar
Sorry, a little confused here, you say
Would appear that you are listing 1 too many satellites there for 2 LNBs.
__________________
Rolf
Donate
Old 26-08-2004   #3
I rolfw. Thanks for quick answer.
In fact I do not know how many LNBs I have; what I know is that I can catch channels from Astra, Hotbird and Hispasat.
Neverthless, concerning the non-visualization of the coded tv channels from TV Cabo, cn you help me please?
Thanks.
Old 26-08-2004   #4
rolfw's Avatar
Are you able to watch Andalucía TV on Hispasat? Have you tried dropping a new softcamkey into ProgDVB?
__________________
Rolf
Donate
Old 26-08-2004   #5
I can only verify that later (i'm at work wright now ). How can I drop a new softcamkey into ProgDVB?
Thanks once again. Hopefully and with your help I'll overcome this...
Old 26-08-2004   #6
rolfw's Avatar
You simply download it from somehwere like Toecutters, it will be attached to the Mach1 or DJMaff 6 in 1 file and then I believe it just drops into the ProgDVB route directory, there will be details in another thread. Excuse the vagueness of that reply, but I haven't run ProgDVB for a couple of years.
__________________
Rolf
Donate
Old 26-08-2004   #7
Where I can retrieve the file from? I do not know Toecutters... what is that? Sorry , can you clarify me? In which thread will be the details?
Thanks.
Old 26-08-2004   #8
Nasty Dish Obsession
Lancelot's Avatar
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H
...And thou were the truest friend to thy lover that ever bestrad horse..."
S**tcam
Here... try this
http://www.satellites.co.uk/php-bin/...tachmentid=633
__________________
I've got an inferiority complex, but it's not a very good one.
Lancelot is offline   Reply With Quote
Old 26-08-2004   #9
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
Thanks.
As Rolfw said, just drop the softcam key into the Progdvb root directory. Details can be found how to do this at the top of this thread.
Toecutter's forum is listed in Nobby's Big List in this forum's main section.
Llew is offline   Reply With Quote
Old 26-08-2004   #10
Originally Posted by Lancelot
Here... try this
Thank you. What is the exact name that the file must have and where should I put it? In the ProgDVB root folder only?
Old 26-08-2004   #11
Lancelot's Avatar
Yes. whether you use the downloader or get the file from a single website
it should be called softacam.key and only needs to be in the root of Progdvb
where Yankse or whatever softcam you are using will pick it up.
__________________
Old 26-08-2004   #12
Sorry, the filename is "softacam.key" or "softcam.key"?
I'm doubftul from your response.
So, I should get to see the crypted channels right? There is no known problem with sky star USB and progDVB that may prevent me from seeing the channels?
Old 26-08-2004   #13
rolfw's Avatar
The file is softcamkey http://67.43.4.157/showthread.php?t=84821
As far as I know there is no diference between the USB and PCI version with regard to decrypting.
__________________
Rolf
Donate
Old 26-08-2004   #14
Having this, I just need to install ProgDVB, the softcamkey file in the root directory and the Yankse plug-in in the root directory also, right?
Thanks.
Old 04-09-2004   #15
Lancelot's Avatar
Red face Poxy Typo's.............. (sorry)
Oooo I feeel such a foool
__________________
Old 04-09-2004   #16
BGonaSTICK's Avatar
Ahemm, hasn't 'fool' just got the two 'o's?
__________________
Old 04-09-2004   #17
Lancelot's Avatar
Q E D
My point exactly......
__________________
Forum Jump
Similar Threads
BSkyB commits to free Sky One net1 B Sky B Digital and 28.2 East General 2 09-11-2004 01:14 PM
Sky unveils plans for Plus net1 Sky+ and PVR Systems 0 03-03-2004 08:24 PM
Star channels in Sky Family net1 B Sky B Digital and 28.2 East General 0 26-01-2004 02:06 PM
Changes To Sky Movies net1 B Sky B Digital and 28.2 East General 0 20-10-2003 07:00 PM
Sky One looking for Next Action Star net1 B Sky B Digital and 28.2 East General 0 01-08-2003 08:27 PM
