TV recording software
Thread Tools Display Modes
Old 27-08-2004   #1
My System: Illusion M3
Can you please inform me if there is any plug-in for ProgDVB or any other DVB software than allows to record tv video signal by programming/scheduling. For example, select to record a transmission that will take place at 20 p.m. next sunday?
Thanks.
nmigreja is offline   Reply With Quote
Old 28-08-2004   #2
Unless I'm reading this question wrong, you can already do this in the full install of ProgDVB. If you go to the service menu there is a scheduler. Programming it is a bit annoying though, but it was there as standard on my copy.
damhy is offline   Reply With Quote
Old 30-08-2004   #3
I've noticed there is damhy, thanks. But programming it as you say is annoying. I can not manage to select the channel that the scheduler must record...
Do you know of any guide that could help performing this task?
Thanks.
Old 30-08-2004   #4
has a Regular Member
Z3r0's Avatar
Thanks.
Just use the channel number when setting the EPG. You can get this by right-clicking the channel name and selecting Channel Property.
Z3r0 is offline   Reply With Quote
Old 31-08-2004   #5
Long Term Contributor
s*t*a*r*m*a*n's Avatar
I have progDVB running great but i am still having the old problem of not being able to get the brightness up, i even installed trial version of cyberlink dvd software thinking it owuld install a codec i need as cyberlink is mentioned in the audio/video menu of progdvb. There is a brightness available but it is always dimmed and cannot be changed and i am sure i have direct draw installed as standard, doesnt matter which operating system i use, same result. How do i enable the brightness level? i have seen it on one occasion work ages ago but not sure how i managed to do it.
and now also miraculously enough when i record some tv i am actually getting a full screen picture as opposed to smaller screen in the past using same version when file is played back in windows media player etc, strange.
s*t*a*r*m*a*n is offline   Reply With Quote
Forum Jump
Similar Threads
NOW you can turn your receive super to ultra enter here jack0 Receiver software, international Section 364 2 Weeks Ago 12:26 PM
Microsoft Pre-release Software License Terms Satdude Daily Satellite and Broadcast industry News 2 26-04-2006 03:56 PM
restore software version for strong 4350 dreher Receiver software, international Section 2 25-03-2005 12:55 PM
Sky+ recording problems pjb Sky+ and PVR Systems 4 17-06-2004 11:46 AM
EPG Software & Sky's New Cards denis1501 Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 9 22-10-2003 03:52 PM
