Control moteck DiSEqC DG 2100 with PCI card!
Thread Tools Display Modes
Old 04-09-2004   #1
hello there,
a little bit late to ask now as after my attempt to build up motorized system controled via PCI edned with buying one 1.2m dish, one 1m dish, one 80cm dish, Moteck DiSEq 1.2 motor, 5 lnbs, first negative feedback on Ebay and more, and hasnt finished yet
Now I need only the PCI card to watch and dont want to end up buying every brand and model of them again.
I know there are many threads about PCI card. I have chosen
DVB-S / Sat Tuner Karte VisionPlus + FB + SkyDSL + Text
btw what do you think about it? I know, it's !!Expensive!! Well the price is the only parameter which makes sense to the newbie
it supports DiSEqC 1.2 and has got 400mA LNB max supply current. Moteck DiSEqC 1.2 2100 motor has got 350mA max consumption. So do you think that the DiSEqC from this card will rotate the dish???? Could you recommend any other PCI card that supports DiSEqC 1.2?
THANKS
p/s: glarus apologizes for any headaches this lame quiestion might have caused you.
glarus is offline   Reply With Quote
Old 04-09-2004   #2
rolfw's Avatar
It is a TwinHan clone card, so should be fine. Always a bit suspicious of Ebay sellers who do not accept Paypal or credit card though.
__________________
Rolf
Donate
Old 04-09-2004   #3
Do you thing it's ok...oh boy! May be this will be The One.
DO you think it will rotate the dish????
How about this one
http://cgi.ebay.co.uk/ws/eBayISAPI.d...119607704&rd=1
do you think it's a good value for money?
Old 04-09-2004   #4
Ding Dang Doo
gameboy's Avatar
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life!
They have a good feedback rating of 99.8% on 3633 items.
Like a lot of ebayers they may well take PayPal but don't like the fact that they cannot pass on the charges anymore ( Ebay do not allow this now).
They can still offer you PayPal when you contact them and they are then allowed to pass on the 5% most take for using that payment.
A money transfer will cost you around £20 and a Euro cheque £12 so makes PayPal instant payment look good value even with 5% added.
As for the price - don't know much about these cards but isn't £40 cheap?
It has DiSEqC 1.2 so it should move the dish without another connection.
gameboy is offline   Reply With Quote
Old 04-09-2004   #5
thanks m8...very heplful. I also though so... asked the seller and he answered that it wouldnt be able to drive the motor but he might be more incompetent than me - that Moteck motor uses the same power supply as the LNB so it should work.
Tell us what do you think about http://cgi.ebay.co.uk/ws/eBayISAPI.d...119607704&rd=1
btw What card do you use?
Old 04-09-2004   #6
Ding Dang Doo
gameboy's Avatar
Use a Mac so no card - Dreambox in my sights.
Cannot imaging a PC Card that has DiSEq option that won't move the dish - but then I may be wrong (I'm good at that!).
Power has to go through the cable to switch polarity of the LNB but I don't know if the motor requires too much.
DiSEq 1.2 does other things than move the dish so maybe the answer is here.
Someone here will know I'm sure...
Old 04-09-2004   #7
Ex Arcade Bandit
prof's Avatar
Hi Glarus,
Recently bought skystar2 from them, £46 inc. p&p no hassle.
prof is offline   Reply With Quote
Old 04-09-2004   #8
Red face
wow, didn't know that. If I use other card skystar2 for instance which supports DiSEq 1.0 will it move the dish?
prof answered my question befere I could submit it
thanks prof
btw what motor do you use?????
Old 04-09-2004   #9
rolfw's Avatar
Most of the popular satellite cards will move a motor, but they are on the edge of their power supply capabilities.
The Skystar2 and Skystar1 will, I believe that the Twinhan will also.
You need to ensure that the make and model you choose is supported by the popular 3rd party software viewers, or you will end up with a free to air system. Have a look at DVBNetworks, link in Nobbly's Big Links, in the satellite forums section.
__________________
Rolf
Donate
Old 04-09-2004   #10
wow, huge source!!! Thanks guys! You are GREAT!!!
Old 04-09-2004   #11
Ding Dang Doo
gameboy's Avatar
Some good information on DisEqC and how it works here...
http://www.satcure.co.uk/tech/usals.htm
See what you think.
Old 04-09-2004   #12
rolfw's Avatar
Many of the users here have been using the SS1 and 2 to drive Moteck SG-2100 motors (me included), works well.
__________________
Rolf
Donate
Old 07-09-2004   #13
hi, just found this forum tonight hunting around for solutions because ime having problems with ss2 and Moteck SG-2100 as in i cant get the motor to turn remotely only by pressing the button by the motor. my ? here is how do you get it to work?.
thank in advance.
carp52 is offline   Reply With Quote
Old 07-09-2004   #14
rolfw's Avatar
Bit more information about the sftwrae you are using will be helpful. With most of the viewers, you need a separate DiseqC plugin.
__________________
Rolf
Donate
Old 07-09-2004   #15
ProgDVB but that says Device not started and dvbviewer. extremely new to this so go easy on me.
cheers
Old 07-09-2004   #16
BGonaSTICK's Avatar
You will need a plugin to move the motor.
Search out the item called 'DISEqC plugin SS2 V1.7' here :- http://www.skystar.rs.ba/programi.html
...but it sounds like you may have other problems to sort out first.
Can you watch satellite TV on your setup as it is?
If so, then you're ok. Just plug this in. Instructions included in that pack. Make sure you replace the correct version of your Technisat driver. Come back if you need more help.
STICK
__________________
Forum Jump
Similar Threads
HDTV with DVB-S PCI card? OldBen Satellite PC Card Systems & Internet by Satellite 4 28-02-2006 12:25 PM
ZENEGA CD -1002S software needed for Dish TV India- Part II Tom Robert Indian Subcontinent General Section 467 02-08-2005 12:55 PM
MR 1.04 & NOVA card (IRD2) & Manhattan 3300 Arkadian Matrix Reloaded, Revolutions and CAS interface 20 08-05-2004 02:59 AM
Pentamedia card not initializing s*t*a*r*m*a*n Computer Discussion 1 14-07-2003 05:07 AM
