PCI vs USB
Thread Tools Display Modes
Old 07-09-2004   #1
Allen1066's Avatar
PCI vs USB
What are the differences between the PCI and USB versions of the SkyStar 2 decoder ? Assuming the functionality is the same, what are the advantages/disadvantages of each format ?
Thanks,
Allen
Allen1066 is offline   Reply With Quote
Old 07-09-2004   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
Thanks,
Allen
The software is exactly the same. Obvious difference is no need to add another card in the PC, especially if you are short of PCI slots.
Llew is offline   Reply With Quote
Old 07-09-2004   #3
Allen1066's Avatar
Is the USB fast enough to handle as much data throughput as the PCI bus ?
This might be the solution to building a SFF PC as it would keep down the internal temperature, what do you think ?
Old 08-09-2004   #4
BGonaSTICK's Avatar
The USB version is excellent, and can do everything that the PCI version can do EXCEPT drive a dish using diseqc 1.2.
I have both the PCI and USB versions.
Heat build up and power consumption is a major problem in a small case, so USB is ideal if you have no motor. That's why I bought mine.
The driver software is 'standard' between the two versions, but different components are installed, based on which version you have.
STICK
__________________
Forum Jump
Similar Threads
skystar pci or usb 4ever Satellite PC Card Systems & Internet by Satellite 4 26-03-2005 03:00 PM
New soft ware for Infinity usb Programmer. rabbi Cards & Programmers General 1 07-09-2004 01:05 AM
What Modem Pci Card do Netsystems use? Mr G Satellite PC Card Systems & Internet by Satellite 1 06-12-2003 01:47 AM
SAt pci card ? ? ? MasterAbacus Satellite PC Card Systems & Internet by Satellite 3 19-09-2003 12:25 AM
gizlog1.3 and twinhan pci card radiotech Satellite PC Card Systems & Internet by Satellite 1 18-08-2003 08:47 PM
