Getting started with SS2
Thread Tools Display Modes
Old 09-09-2004   #1
ianfoster's Avatar
Unhappy Getting started with SS2
I am on a steep learning curve and need a mentor!
I have a skystar2 PCI Card (Ebay-EOL)
I have loaded the latest drivers (4.2.11.9999)
Running Win XP
Dual LNB & 80CM Dish - Getting pictures on Analog Receiver
Using DVBViewer it finds 84 Channels
But I get No Pic or Sound
Signal is 75%
Is it true that even if card is locked the latest driver solves this
How do I Check if it is locked?
What else could be wrong
Do I need Codecs Loaded - How can I tell if any are loaded - How do I Get them and load them if needed
I need a Patient Tame Expert
ianfoster is offline   Reply With Quote
Old 09-09-2004   #2
rolfw's Avatar
Try first with another viewer, if you have XP, then try MyTheatre. Some of the ex EOL cards can be locked, but there is unlocking software around.
__________________
Rolf
Donate
Old 10-09-2004   #3
ianfoster's Avatar
I have now tried My Theatre
BTW I am pointing at 19.2
When I scan It claims to find 91 channels
But I can not get picture or sound
What are Graphs and why do I get a "..... Not found" error when I select one
Old 10-09-2004   #4
BGonaSTICK's Avatar
See attached from Technisat. It doesn't mean to say the some of the unlocking software doesn't work, but it should be a last resort or it could be bye-bye card.
STICK
__________________
Old 10-09-2004   #5
BGonaSTICK's Avatar
Did you install them when you had the MyTheatre install option panel come up?
Try re-installing and tick the graphs, codecs etc options. You can safely install MT V2.76 over the top of a previous V2.76 install.
__________________
Old 10-09-2004   #6
ianfoster's Avatar
Yes all were ticked.
I am using Version - MyTheatre v3.12
Old 10-09-2004   #7
rolfw's Avatar
Use version 2.76, better version and easier to get running properly.
__________________
Rolf
Donate
Old 11-09-2004   #8
ianfoster's Avatar
Downgraded to version MT 2.76
uninstalld previous version
selected all options for install
Scanned all transponders found nothing
Still finds 64 with ProgDVB
Where to now?
Old 12-09-2004   #9
BGonaSTICK's Avatar
Your card may be locked, but it sounds like your dish, LNB or cable might not be right. You should find hundreds of channels on 19.2E. Try with a different digital receiver if poss, as rolfw said.
STICK
__________________
Forum Jump
Similar Threads
Transponder update 04/11/03 Satdude Transponders & channels 0 04-11-2003 09:41 PM
Transponder update 03/11/03 Satdude Transponders & channels 0 03-11-2003 10:56 PM
Transponder update 15/09/03 Satdude Transponders & channels 0 15-09-2003 09:51 PM
Transponder update 01/09/03 Satdude Transponders & channels 0 01-09-2003 04:24 PM
Transponder update 29/08/03 Satdude Transponders & channels 0 29-08-2003 04:25 PM
