Have a doubt which card to choose
Thread Tools Display Modes
Old 16-03-2005   #1
d_lamer2003's Avatar
My System: skystar 1 + Motorised dish.
Question Have a doubt which card to choose
I am new here, so please bear with me, if this question have been asked a milion time before maybe.
I am think of buying a sat pc card. I am deciding of buying eitheir TechniSat SkyStar 1CI TV PVR or Twinhan Vision DTV Sat-CI 1030A which one do you think should I buy and also, can someone point me out, to a good tutorial, (plain english) about satellite tv.
Thanks for your help guys.
d_lamer2003 is offline   Reply With Quote
Old 16-03-2005   #2
BGonaSTICK's Avatar
The Skystar1 probably has better support, and is more popular (IMO).
This is as good a place as any to get started. Ideal for beginners, as we're a friendly bunch and we'll take it at your pace if you have any questions.
Plenty of beginners guides here too.
__________________
Old 16-03-2005   #3
hi, be carful with a sky star 1 i puchased one with ci module but the drivers did not like windows xp.
i would recomend the sky star 2 as it uses soft cam keys and works brilliantly with prog dvb, have fun!
emcone10
emcone10 is offline   Reply With Quote
Old 16-03-2005   #4
BGonaSTICK's Avatar
Don't know of any driver issues, but it's possible. I wouldn't buy it for the CI, I'd buy it for the hardware decoding. Far superior to the SS2 (which I have and love to bits).
__________________
Old 16-03-2005   #5
OK maybe a iconpatabilty with my mother board, changing the subject can you tell me if its possible to pick up the italia bouqet with my ss2 ?
regards emcone 10
Old 16-03-2005   #6
BGonaSTICK's Avatar
Yes, but not Pr!ma F!la or Sp*rts. Will all become unavailable very soon.
Use S2emu V1.14 with all the other files released with V1.12.
STICK
__________________
Old 16-03-2005   #7
Talking
cheers mate ill give this ago tomorrow and let you know how i got on
Old 17-03-2005   #8
10x for all your fast replies guys.
Now I am interested in the following cams, dragon and magic cam and also some of the cams that are found on this website. _http://www.brymar.co.uk/acatalog/Satellite_CAM_s.html
Do you think that the Skystart works with those cams I mentioned above. I have to use some sort of cam, because otherwise, where I live, I am only able to recieve view free to air channels.
And what I meant by the question if someone can point me to a good websites, where I can learn more about satellite tv, I meant for tutorials, and stuff like this, to get me started, because I am not accustomed to certain jargon.
Old 17-03-2005   #9
BGonaSTICK's Avatar
The Dragon is an excellent CAM, but you do realise that you can perform a lot of decryption in software emulators with the Skystar1 if you don't mind getting your hands dirty?
There are many guides in this forum. Many are included in 'sticky' threads, posted at the top of most of the individual sections.
Another good site is www.duwgati.com although it gets out of beginner territory pretty quickly.
Have a look in our links section for directions to many other high quality sites.
STICK
__________________
Old 17-03-2005   #10
First of all stick 10x for your help.
What u meant by getting your hands dirty, u meant fiddlying with the card, electronics part. Or changing some stuff from the inside of the software which the card comes with?Because playing with software I am good at it, but playing with hardware, I am none
10x again, you and the others have been of a lot of help.
Old 17-03-2005   #11
BGonaSTICK's Avatar
Fiddling around with the software should get you some encrypted stuff you wouldn't otherwise get without a CAM and a subscription.
I can only speak for the Skystar2, but I'm pretty confident that the SS1 will do some interesting things too.
__________________
Old 18-03-2005   #12
farr's Avatar
My System: XP2000, Windows XP Professional, Skystar 2, 78cm dish with 3 LNBs pointing at 13E, 19.2E and 28.2E
Going slightly off topic on this, DragonCAM users had S*y Ita*ia and Digit*l+ back a good few weeks before DVB card users did in late November. I realise things have changed now and it's likely ALL users will lose all channels on the two packages soon anyway, but it was certainly one (albeit temporary) advantage of owning a DragonCAM over just software.....
farr is offline   Reply With Quote
Old 18-03-2005   #13
BGonaSTICK's Avatar
Yes, very true, and I'm not knocking those who went out and bought Dragon CAMs, cards and programmers but if they had either a Dreambox or a PCI card anyway, they did pay a lot of money for a few weeks viewing.
__________________
Old 18-03-2005   #14
First of all thanks BGonaStick for your help.
I have some questions not directly related to the cards, but I dont want to open a new thread .
Ok, I know your gonna tell me search the forum for this question, but I am gonna take a chance . STICK can you gimme a link, or a website, so that I can see how I can make this happen.
And another question not directly related to the cards, is there a website which shows you, what free to air channels there are by country or latitude. I know about lynsat, but Its a bit technically, for a noob like me .
Old 18-03-2005   #15
BGonaSTICK's Avatar
Lyngsat is really the best place to get the info you need.
One or two other places you might find interesting are :-
_http://www.kingofsat.net/en/
_http://www.ultimatetvguide.com/ppvguide.htm
_http://www.digitalsat.co.uk/frontpage.html
or check out our links section here.
This post in particular will help you :-
Help to the other newy's for their SkyStars
Read through our PCI cards section here. It will tell you exactly how to set up the SS2, and you can modify it for your SS1. I know CAPI works with the SS1.
STICK
__________________
Old 18-03-2005   #16
Many thanks STICK, once again.
Much appreciated.
Old 19-03-2005   #17
Just to say, I presume the SkyStar1 CI you are talking about is the newer model which doesn't have hardware decoding (I believe), unlike the old SkyStar1 cards, so it wouldn't have any advantage in that sense over the Twinhan card. I also would check first that it is compatible with the many third party softwares that both the old Skystar and the Twinhan cards are.
Frazer
FRAZER is offline   Reply With Quote
Old 19-03-2005   #18
BGonaSTICK's Avatar
That's very interesting. I didn't know that, thanks for pointing it out. I just checked on the Technisat site; it looks rubbish!
I just found this one on a very quick search, so I guess you can still get them with on-board ATM.
_http://www.dvbshop.net/product_info.php?products_id=193
With no onboard decoding and no TV-out I can't see much advantage over the Skystar2 (other than the CI slot obviously). With a fast CPU and a top quality graphics card, it produces some great results.
Maybe you can track down a Nexus-S which is based on the old card.
_http://www.hauppauge.com/pages/products/data_nexus.html
__________________
Old 19-03-2005   #19
Unfortunately now I already bought the technisat SkyStar 1.
I bought the card from here _http://www.sateuropa.co.uk/product_overview.asp?id=656&catid=1&subcat=7]
Strangely enough the information contain on this website, have more information than the technisat official site!
Just out of curiosity, the link that you gave me STICK of the technisat card in your last post, the card shown have a connection to connect the card to the sound card. The card I bought (I still have to recieve it by post), Does not have any connection for a sound card. Excuse this noobish question, but does this mean that I bought a card, which does not recieve sound?
Old 20-03-2005   #20
BGonaSTICK's Avatar
I don't know about the sound card connection on your card. My SS2 doesn't have one, and it doesn't need one.
Fear not!
__________________
Old 20-03-2005   #21
I would see silent movies like our ancestors used to do, way before tv was invented.
Forum Jump
Similar Threads
Matrix Reloaded How To by AHAC rolfw Matrix Reloaded, Revolutions and CAS interface 52 27-12-2005 12:02 PM
Need Help for program Titanium Card by WinExplorer coconut Cards & Programmers General 6 02-02-2005 06:02 PM
Which DVB card? alnitak Satellite PC Card Systems & Internet by Satellite 4 26-08-2003 02:17 PM
Pentamedia card not initializing s*t*a*r*m*a*n Computer Discussion 1 14-07-2003 05:07 AM
new card don't work Robbiewright Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 3 25-06-2003 09:05 PM
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the view
