Skystar2 + Smartmouse + Valid card
Thread Tools Display Modes
Old 28-06-2005   #1
My System: Skystar2 PCI P4 2.6Ghz 1024MB PC3200 XFX 6800GT
Is it possible to decrypt Irderto2 and/or Viaccess2 channels using a Skystar2 pci + smartmouse card reader + a valid subscription card with a software cam?
Thanks,
paradoxni is offline   Reply With Quote
The Following User Says Thank You to paradoxni For This Useful Post:
ej_ebrahim (15-04-2008)
Old 13-07-2005   #2
mansoura's Avatar
My System: Sat SkyStar2 PCI Ver.2.6D
Talking
yeah You cand do it but before that download this file and put it in plugin file for the program you use to watch TV if you use progDVB put it in this directory C:/ProgDVB
after that open ProgDVB and go to plugins then u see IrdetoCAM click on it then Go to Setting and choose a Com Port u connect a Smartmouse.
now put a Valid Card for Irdeto2 and Have Fun
This will not decrypt any channels without a legitimate Card
Thanks,
mansoura is offline   Reply With Quote
The Following User Says Thank You to mansoura For This Useful Post:
Old 09-08-2005   #3
i keep getting " incoming ecm instruction.....signature wrong" over and over! I have all the settings correct
Old 10-08-2005   #4
im thinking perhaps the new card cannot be activated by this method, perhaps it needs a proper set top receiver. Anyone in Northern Ireland fancy activating me card?
Old 22-08-2005   #5
Try md irdeto cam 1.07_01 beta......
This version doesn't have autoECM, so you will have to manually select the ecm (go to the channel properties in progdvb and double click on the correct ecm...)
You will also need to enable EMM for your card to activate, leave it running tuned in the channel for about 1 hour to activate and receive the keys...
Good luck...
deliol is offline   Reply With Quote
The Following User Says Thank You to deliol For This Useful Post:
Old 22-08-2005   #6
Good luck...
ok tryin that thanks...its currently receiving ecm instructions..seems to be doing different stuff than before..fingers crossed. am I correct in assuming that irdeto CA type is the one ending 604 ?
Old 23-08-2005   #7
can someone help me in this matter?
Are there any specific settings need to be entered in the IrdetoCAM ?
hamham is offline   Reply With Quote
The Following User Says Thank You to hamham For This Useful Post:
Old 26-08-2005   #8
Yes , Irdeto ECM are of the type 6xx (604,622,624,etc)
Just double click on it and watch irdeto cam monitor.... should work
However, if mdirdetocam plugin cannot activate your card, you will have to use o receiver box with an irdeto cam for it... then put the card back to your pc, will work fine
Old 26-08-2005   #9
I receive plenty of ECM instructions, but still not working, so I assume ill need a proper irdeto CAM to activate as you say. The problem is I dont know anyone with one.
Old 02-09-2005   #10
Have you enabled the EMM setting???
Also enable the Emm Logging , it will create a file in the progdvb folder with all the emm commands... send it to me and i'll sent it to the author of irdetocam plugin, maybe he can help.... ( a screenshot of the plugin monitor while recieving emm's would help too)
Old 22-09-2005   #11
ok just sent the card back to where I bought it to be activated and tested as working...still not working here thou
Old 12-04-2008   #12
hi guys is there a link to md irdeto cam 1.07_01 beta ?
thanks
SAM
Sam_digital is offline   Reply With Quote
Forum Jump
Similar Threads
Skystar2 + Smartmouse + Valid card paradoxni Satellite PC Card Systems & Internet by Satellite 2 08-03-2006 05:47 PM
Matrix Reloaded How To by AHAC rolfw Matrix Reloaded, Revolutions and CAS interface 52 27-12-2005 12:02 PM
Pentamedia card not initializing s*t*a*r*m*a*n Computer Discussion 1 14-07-2003 05:07 AM
