Channel list for ProgDvb | |
| Nasty Dish Obsession Join Date: 01-06-2004 Location: Oxfordshire
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." |
For 4.6.2 onwards. From 58W to 36E. I will update periodically. This should give you a head start and save a lot of scan time. Just unzip into c:\progdvb\channels. Comments welcome. Rgds L. ![]() Updated 09/05/06
__________________ I've got an inferiority complex, but it's not a very good one. Last edited by Lancelot; 09-05-2006 at 01:46 PM. | ||
| The Following User Says Thank You to Lancelot For This Useful Post: | Shery32 (13-07-2008) |
| Specialist Contributor Join Date: 05-11-2005 Location: cheshire,algeria
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up ![]() Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad | nice work lancelot, the only trouble i can see is that not everybody has the capacity to get all them sats, maybe you could trim the list occordingly where by depending on your dish size etc you have a choice of say 4 options (channel.zips) that way some one whose using a porty potty can use minimum, and some one who has access to seti can use maximum, just a thought, maybe you can do a poll as to see if size does matter ![]()
__________________ ![]() ![]() polite notice: do not hijack threads,do not double post, ![]() ![]() ![]() search and ye shall find (before you ask) ![]() ![]() ![]() | ||
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | As you know, they will come out as tabs on the ProgDvb screen. In theory it could be split, but lots of work involved for differing locations and dish sizes. So just choose your sat by tab, and any you can't get on that sat are out of reach or not transmitting. (it's only 350Kb) But have a go for your location, and edit and add to yours accordingly. Will be interesting to see the different additions/subtractions between the two. L. ![]()
__________________ I've got an inferiority complex, but it's not a very good one. | ||
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up ![]() Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad | ever played tennis
| | #5 | ||
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Management courses are a wonderful thing ![]() l. ![]()
| | #7 | ||
| Member Join Date: 08-05-2006 Location: Spain
My System: 60 cm, 0.5 lnb, 25m cable. In a few weeks: 100/110 cm, Motsat3, 0.2/0.3 lnb/ 15/20m cable. | I've have a problem. When I unzip the file into the Channels folder, starting up the Progdvb, an error appears, and automatically closes it . But without any content on this folder it works properly...My current version is: 4.48.2 tHANKS | ||
| | #8 | ||
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Ah.... You need 4.62.6 or later (the ones with the ProgDVB engine) to use it. Rgds L. ![]()
| | #10 | ||
| Long Term Contributor Join Date: 01-05-1999 Location: scotland
![]() | Would love to see one for feeds but i guess that would be a lot of time and effort and then the feeds would probably disappear just as quick. I like the channel.zip excellent thanks and yes channel lists for each sat would be nice but its no big deal just changing the satellite tabs at bottom of progdvb really isnt too much of a problem for me anyway ![]() | ||
| | #13 | ||
| Member Join Date: 29-03-2004
| Thanks Lancelot, Its a very useful list. Also, related to feeds, would you please be able to advise me how to add the parameters for a feed to the list. There is a feed on 1W that is regular and I wish to add it to the list so that it is picked up when I scan the satellite? Alternatively, can I scan for a channel manually in ProgDVB when it is open so that it scans the one chosen frequency that is not present in the channel lists? I have ProgDVB 4.80.1 but have only used it for scanning a full list on a satellite. I have not used it for scanning individual freqencies not in the channel lists. Regards | ||
| | #14 | ||
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | You can add the transponder(s) manually by opening up the .ini file for the satellite you want using notepad and saving it again, or if the transponder is live when you are on it you click in ProgDVB on 'Channel List', 'scan transponder', then alter the parameters you need to then click on 'scan'. Rgds L. ![]()
| | #15 | ||
| Regular Member Join Date: 30-04-2006 Location: yookay
My System: Nothing at the moment until I find a remote for BigSat 6600CI. Pls see if you can help! | | ||
Similar Threads | ||||
| The forthcoming channel list for Sky | Analoguesat | B Sky B Digital and 28.2 East General | 6 | 03-03-2007 08:48 PM |
| Transponder update 30/10/03 | Satdude | Transponders & channels | 0 | 30-10-2003 09:02 PM |
| Transponder update 20/10/03 | Satdude | Transponders & channels | 0 | 20-10-2003 03:52 PM |
| Transponder update 20/09/03 | Satdude | Transponders & channels | 0 | 20-09-2003 08:26 PM |
| Transponder update 21/08/03 | Satdude | Transponders & channels | 0 | 21-08-2003 05:25 PM |
