Satellite internet?
Thread Tools Display Modes
Old 18-08-2003   #1
My System: Innovative, Diseqc Motor, 80cm dish
Satellite internet?
Anyody know if there are any satellite broadband isp's available on hispasat 30w?
Cheers
homerjay is offline   Reply With Quote
Old 18-08-2003   #2
rolfw's Avatar
Not as far as I know, certainly never heard of one.
__________________
Rolf
Donate
Old 23-08-2003   #3
My System: Kabel BW
Yes there seems to be one. Found this link here:
http://www.digicomnet.org/english/?s=info
from here:
http://forums.dvbnetwork.com/viewtopic.php?t=13883
Looks like a serbian reseller and the satellite mentioned to be used is the Hispasat 1D.
Despite of that i couldn't find on lyngsat any frequency on this satellite beeing shown that there is data transfer.
Some months ago in a greek sat magazine i read of a 2Mbit/s service from Hispasat going to start, so might be that it hasn't started yet.
deepbluesky is offline   Reply With Quote
Old 26-08-2003   #4
cheers for the info deepblue,
99€ for 512k seems a bit steep, hopefully the price will come down soon!
Old 26-08-2003   #5
Irish Mod
Razor's Avatar
If anyone here has sat internet I would be interested to know how good/bad it is.
Been thinking of buying a sat card for some time now.
__________________
Don't mind my spelling
Razor is offline   Reply With Quote
Old 26-08-2003   #6
My System: Kabel BW
From what i hear sat internet is only a solution in regions where still terrestrial broadband lines aren't available. If you have the possibility to get xdsl/cable/fibre optical/wireless internet access don't go for it.
The reasons are these:
Some contracts have limits on the amount of data you can dl or ul (if 2way). If you pass this limit you pay per GB and it can get very expensive. Lately there are unlimited services but let's say that you pay for a 512 dl connection and 2GB of data are guaranteed at this speed. If you exceed the 2GB the speed will fall since your data packets are of lower priority on the system compared to others who are still below the 2GB. I am not sure if this problem have all the sat-isp's but be warned. Have heard from a person that had 512 down and since he exceeded the limit the speed fell to analogue-modem-level !!!
There is also another problem:
Real satellite flatrates are expensive just because you need an uplink to satellite with a transmitter (costs at least 1500€) beeing installed on your dish and perfectly aligned and configured. If not then the whole network of the isp can break down. That's what someone told me knowing more. So the hardware is expensive and the monthly fees are too. This 2way provider
http://www.star-duo.com/
of what i have read in the DVBN-Forum seems to be quite ok although i haven't seen it with my own eyes and so i cannot really recommend it to anybody. But as good the service might be the ping times will be high since the signal has to travel a while to the sat, and beeing sent to the ground station to the isp. So don't be surprised if you see numbers like on an analogue connection. Knowing this you can forget online gaming over a 2way connection. I think also voice- and videochat won't work well or with very high delay.
Another one-way-provider is this one which is recommended of some people:
http://www.broadsat.com/en/opensky/
Finally i want to give you an idea also. If there are some people interested in your surrounding and a flatrate is available anyhow, either over sat or further away over dsl then over Wireless LAN an access could be provided to those beeing far away from the access point.
In Greece for example where flatrates are very expensive til the moment (120€ a month for a 384/128) people exchange data between them over WLAN. The network has risen in a few months to the biggest in Europe just because of the high dsl-fees. Although internet access isn't provided yet one can have theoretically up to 11Mbit/s transfer rates over the air. Practically it's about half of this speed. So if you live on the edge of a dsl- or cable-broadband area and have a friend or relative beeing inside he could do the connection and you over WLAN using his line and each of you pay half of the price. Just an idea which might help some here.
Old 26-08-2003   #7
Irish Mod
Razor's Avatar
Thanks DeepBS I am now very well informed.
At home I am outside the HighSpeed loop. With no cable, and no choise I might have to look at sat.
Speed wise at the moment is very slow(very old copper) and is that bad, if I see YOU ARE CONNECTED 28.8K that is about as high as it gets.
__________________
Old 26-08-2003   #8
rolfw's Avatar
There are a couple of services on Astra 19.2 and I believe that there may also be one on 28.2.
Having taken this route in the past, it really is only to be used as a last resort, two way is too expensive and downlink only, still requires a terrestrial ISP with an anytime connection. It is no good for gaming, as the lag is 300ms plus and is subject to similar congestion as the regular internet.
Add all of this to the download restrictions and the problems caused by using VPNs with some of the services and it really doesn't make it too worthwhile.
__________________
Rolf
Donate
Old 26-08-2003   #9
Irish Mod
Razor's Avatar
I think CH said that he trails 2MB pipe, now thats what I would like.
Is his house for sale?
__________________
Old 26-08-2003   #10
rolfw's Avatar
Sure it would be for the right money Razor, got a nice dish on the roof as well
__________________
Rolf
Donate
Old 26-08-2003   #11
Irish Mod
Razor's Avatar
Hang on, I seem to remember something about plumming/heating problems.
They will have to be sorted first.
PS. he can leave the dish, now I will have 4
__________________
Forum Jump
Similar Threads
Digital satellite viewers lose free channels net1 B Sky B Digital and 28.2 East General 5 16-06-2005 01:22 PM
Satellite internet for France net1 Daily Satellite and Broadcast industry News 0 23-01-2004 08:30 PM
Irish satellite Internet from 45E net1 Daily Satellite and Broadcast industry News 0 10-11-2003 06:48 PM
Last-minute deal on free-to-air satellite net1 B Sky B Digital and 28.2 East General 11 29-10-2003 11:29 PM
Will the BBC's satellite dream ever take off? net1 Daily Satellite and Broadcast industry News 0 26-06-2003 08:49 PM
