Skystar2 droping my DSL line?! /!\HELP/!\
Thread Tools Display Modes
Old 27-04-2006   #1
Folding*home
Prophessor's Avatar
My System: [ Relook 250S ]
Unhappy Skystar2 droping my DSL line?! /!\HELP/!\
Hi folks.
I have a Skystar2 + ProgDVB + softcam package running smoothly, but I beem experiencing signal loss on my USB DSL modem. I read somewhere that some people get a similar problem using a 56k modem, the problem being related to the Network Connections on control panel.
- I have tried to disable the SS2 as network pci card, but the driver doesn't allow it.
- Used the S4PC program on startup as normal, but the line keeps droping
- Took S4PC away, but the line keeps droping
- Exchanged modem, but the line keeps droping
- Did a new XP install, but the line keeps droping
- Installed the newest chipset and modem drivers, but...
- Been complaining to my ISP for about a month, they keep saying I have everything 100% ok
When I say that the line keeps droping, I mean that for 1sec I get no signal at all. 10 secs latter I'm surfing at full speed like nothing happened. There isn't a padron, it drops after 1, 2, 4, up to 8 hours.
Is this some kind of problem with the drivers, what am I doing wrong?
Please help!
__________________
When people ask me what I think, I tell them: "I think all of the meat around the pig's ass is pork."
Prophessor is offline   Reply With Quote
Old 27-04-2006   #2
rolfw's Avatar
I have heard of several people experiencing similar problems, but not always due to the Skystar, some of these USB modems draw too much power and if you have other USB devices connected can malfunction. The easiest (yet more expensive) way around this is to get yourself a modem/router and connect via ethernet port, this would of course also make life easier for connection of other PCs/Dreambox/IP Phone to the network.
__________________
Rolf
Donate
Old 27-04-2006   #3
T_G
The Consumate Dreamer
T_G's Avatar
Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything.
Muhuhuhahahahahaaaaarrrgggh
Would an additional USB2 card not help? They are fairly cheap and would reduce the load on the USB if you got several things running on USB
__________________
I only believe stuff that comes straight from Mr. Horses mouth
T_G is offline   Reply With Quote
Old 27-04-2006   #4
Folding*home
Prophessor's Avatar
Those are all good points and I have to try some of them. Well, my mbo has 8 usb ports, 4 are available, 4 are in use, of those 4 only 1 is drawing power all the time. I have tried 2 different usb modems, but still have the same problem, really have to try a modem/router.
ATM I can't find the time to do some more experimenting, but thanks for your input I'll put it to good use.
__________________
Old 28-04-2006   #5
Sir Bronking's Avatar
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up
Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad
have a look here Which is your preferred Viewer for PC satellite TV
from about post 10 there might be answers in your setup
__________________
patience is not a virtue, its a godsend.a picture is worth a thousand words
polite notice: do not hijack threads,do not double post,
search and ye shall find (before you ask)
Sir Bronking is offline   Reply With Quote
Old 28-04-2006   #6
kamaleon's Avatar
My System: skystar2 pci skystar usb + porty lidl camping dish maybe one day i'll have a dreambox 500s...
I'd suggest two things (maybe they're worth nothing, but here they go
give your skystar a fix ip adress
try pluging it into a externally powered usb hub
kamaleon is offline   Reply With Quote
Old 30-04-2006   #7
Folding*home
Prophessor's Avatar
I will read those posts, I think did it before but could have missed something. About the modem/router, one portuguese user has one and is experiencing the same problem. One of our mods sugested, among other things, to move the router as far away as possible from the pc case. Seems to have helped that user, but did nothing for me.
I think technisat is aware of this problem, so just to check them out, I wrote them an email. If I get an answer I'll post it here.
Anyway thanks, I'll give it another go.
__________________
Old 13-06-2006   #8
Folding*home
Prophessor's Avatar
Smile
Solved my problem and killed two birds with one stone. My usb modem was at fault, there was something wrong with it so I send it down the garbage shoot, really hated that mofo! Got a cheap ass modem\router and now my dsl line is solid as a rock and its better looking too.
Thanks for everyone's help.
__________________
Old 13-06-2006   #9
kamaleon's Avatar
nice to hear that mad prophessor
Forum Jump
