diseqc 1.2 and progdvb | |
| Make a wish Join Date: 01-01-2000 Location: London
| Yes, ProgDVB does require a plugin to operate a Diseqc motor. There are a few out there, but the one I use is called Dixie. Jyst add the plugin to the root directory of ProgDVB and then set it up within progDVB. of course you motor should have been setup correctly in the first place and the positions already stored should match the dixie.ini file supplied with Dixie. Cheers.
__________________ ua::no | ||
| Specialist Contributor Join Date: 23-07-2005 Location: S.Wales
My System: 1.2M & 55cm Gregorian Dish`s, 1.5m Gibertini on a Jaeger 1224 H-H motor. Dreambox 7025 200gb HD, Vbox-II. SS2 Card. | Hey search is a wonderfull thing! Try it some time ![]() This might help you a great tutorial. http://www.satellites.co.uk/satellite/dish-setup-single-sat-multi-sat-motorised-systems/53462-start-finish-ss2-progdvb-motor-diseqc.html
__________________ Roiders are like the sun, big, orange, and never stare directly at them | ||
| | #5 | ||
| Member Join Date: 08-12-2005 Location: Hull, UK
My System: SkyStar2 receiver, 88cm Triax dish, Moteck 2100A motor, MCE2005 (1TB), Hauppauge PVR250, Sky+ (120GB), DLAN, X10 etc | I use MiBi's SS2DiSEqC v1.10 with ProgDVB as it works well with my SS2 card. You can get it here: _http://www.dvbskystar.com/ | ||
| | #6 | ||
| Section Leader Join Date: 07-07-2006 Location: INDIA
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Need CCcam Plugin for Progdvb or DVB Dream or any other.
__________________ | ||
Similar Threads | ||||
| Progdvb Question? | ripley607 | Satellite PC Card Systems & Internet by Satellite | 1 | 02-03-2004 12:13 PM |
