conax on pc | |
| Regular Member Join Date: 01-01-2000 Location: pj::
Hi all - great forum. Whats the best way to receive conax channels using a pc setup (1deg W?) mainly to receive the footy (is conax best for footy?) and whats minimum pc spec should i have? Roughly how much cash are we looking at to get started? Cheer in advance Stevie Glasgow
__________________ pc:: | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Hi Stevie, the only ways to receive Conax at the moment is to either buy a a genuine subscription (difficult from the UK), or to buy one of the pirate cards available at £300 or so, these could stop working at any time. Earlier in the year it was possible with a Skystar2 PC card at £60 and a 1Ghz computer, but no longer I'm afraid.
__________________ | |||
| Thanks for your reply mate. So at the moment whats the best way to get the footy (english, scottish, whatever) especially on sat afternoon. Easier on PC or buy a receiver and do my own cards? Do I really need a mototrised dish to get the best footy coverage?
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | There's quite a bit of football available, but to get the best choice you will really need a motor, or more than one dish. Hispasat is good on 30W, plus there is some on 19E as well, not really my thing, but I'm sure that one of the members will be able to give you more information. The Skystar 2 with a good DiseqC motor and a 75cm Raven dish, will probably pull in most of what you want, depending where you are in the UK.
| | #5 | ||
| Specialist Contributor Join Date: 29-07-2003 Location: Chorley, Lancs
My System: Innovative, Diseqc Motor, 80cm dish | I have a skystar2 and 80cm dish pointed at 30w, get quite a bit of footy including a couple of saturday matches and many replays... | ||
| | #6 | ||
| Regular Member Join Date: 11-12-2002 Location: Manchester UK
| Hi Stevie Have a look at http://64.77.87.5/sport/ matches on satelite for the week ( I move my dish by hand ) | ||
Similar Threads | ||||
| Transponder update October 2007 | Satdude | Transponders & channels | 666 | 25-10-2007 11:44 PM |
| Conax plans to set up unit to support CAS in India | net1 | Indian Subcontinent General Section | 6 | 17-08-2006 05:52 PM |
| Conax + tita advice, please | stratosg | Conax, Cryptoworks, Nagravision, NDS and Others | 1 | 11-02-2004 10:57 AM |
| Conax 4.00 e and nagra... | tunte | Conax, Cryptoworks, Nagravision, NDS and Others | 2 | 25-01-2004 12:29 PM |
| Conax to provide CAS to Chile's ZAP TV | net1 | Daily Satellite and Broadcast industry News | 0 | 04-11-2003 07:31 PM |
