HD: forget progdvb use dvbdream | |
| Specialist Contributor Join Date: 05-11-2005 Location: cheshire,algeria
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up ![]() Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad |
go here and download dvbdream v1.1h then get coreavc (don't forget to register it) setup and away u go for now i'll be using progdvb for"normal sat" and dvbdream for hd ![]()
__________________ ![]() ![]() polite notice: do not hijack threads,do not double post, ![]() ![]() ![]() search and ye shall find (before you ask) ![]() ![]() ![]() | ||
| | #2 | |||
| Member Join Date: 07-06-2006 Location: Bedfordshire, UK
My System: none yet :) |
I have the following 3.4MHz DCOre P4 512MB Gainwood Geforce 7900GT 3GB 533MHz Ram I also have the following CoreAVC Pro Codec Powerdvd 7 Trial Codec DVB Viewer (FULL VERSION) Moonlight pack HDTV Pump With all these installed I still get a few frames dropping out on the BBC HD feed. What settings are you using etc.... MORE INFO REQUIRED!!!!! | |||
| | #3 | |||
my system piccy 1 dvbdream video settings piccy2 and (ive not tweaked anything yet) bbc hd draws 100% off me have a look at astra hd 19.2 cpu 75% ish another thing with dvbdream is you don't have to alter settings between hd and "normal" i have coreavc 1.1 pro
__________________ ![]() ![]() polite notice: do not hijack threads,do not double post, ![]() ![]() ![]() search and ye shall find (before you ask) ![]() ![]() ![]() | |||
| | #5 | ||
| Regular Member Join Date: 19-08-2006 Location: UK
My System: Portland DP100 STB, Asus Tiger Hybrid + Kworld DBT100 + Skystar 2 HTPC | Christ your right, been twatting about most of the day trying to convince it to work in DVBviewer (TE), progDVB, dvb portal and skyview and getting nothing, this one works out of the box! Only annoying thing is the loud noise it makes when it finishes a scan, when I have my volume up at max thanks to the low volume levels on satellite. | ||
| | #6 | ||
| Member Join Date: 29-05-2004
Dear I cannot get dvbdream to work. It does not connect to skystar2 and works in offline mode only. Besides I cannot get the coreavc pro to register on command prompt. The message says that window cannot locate regsvr32. Please help. iqbalbhawana*yahoo.com | ||
| | #7 | |||
| Regular Member Join Date: 03-02-2004 Location: London [South East]
My System: CPU Intel® Pentium® 4 640 Prescott (3.20 Ghz) Memory 1024 MB DDR RAM - (2x 512 MB - PC3200) Motherboard ECS 915P-M3 Hard Drive 300GB Maxtor DiamondMax SATA 6B300S0 Skystar 2 usb 1mtr steerable dish Technomate, Fortec, New Wave and Ka | DVB Dream screen No Device Offline Mode.JPG Cannot access.JPG
| | #8 | ||
My System: Portland DP100 STB, Asus Tiger Hybrid + Kworld DBT100 + Skystar 2 HTPC | Looks like you two are having the same problem, it worked for me without any trouble. Perhaps it is because I installed the 4.4.0.0 drivers? h__p://www.dvbskystar.com/down_drivers.html | ||
| | #9 | ||
My System: CPU Intel® Pentium® 4 640 Prescott (3.20 Ghz) Memory 1024 MB DDR RAM - (2x 512 MB - PC3200) Motherboard ECS 915P-M3 Hard Drive 300GB Maxtor DiamondMax SATA 6B300S0 Skystar 2 usb 1mtr steerable dish Technomate, Fortec, New Wave and Ka | Thank you for the info Caned Toad I have downloaded the drivers. Do I have to remove anything or do I open the file and they will install in the right place, thanks | ||
| | #10 | ||
My System: Portland DP100 STB, Asus Tiger Hybrid + Kworld DBT100 + Skystar 2 HTPC | I just went into device manager and selected update driver and pointed it to the SkyNET.INF file, this was from the lite pack. | ||
| | #11 | |||
My System: CPU Intel® Pentium® 4 640 Prescott (3.20 Ghz) Memory 1024 MB DDR RAM - (2x 512 MB - PC3200) Motherboard ECS 915P-M3 Hard Drive 300GB Maxtor DiamondMax SATA 6B300S0 Skystar 2 usb 1mtr steerable dish Technomate, Fortec, New Wave and Ka | Cant get Ctrl Pss to work for sending pic, but foldr contains Size 35.4 MB Folders Install Manuals Software Tools Files autorun.inf demo32exe SKyNET.INF SKyNET.Sys | |||
| | #12 | ||
My System: Portland DP100 STB, Asus Tiger Hybrid + Kworld DBT100 + Skystar 2 HTPC | Yeah, the only files it really needs are the inf and skynet.sys. Full procedure: windows key + pause Hardware Tab Device Manager Button Network Adapters unfold Right Click Technisat and choose update driver No, not this time, next Install from a specific location, next Don't search, next Have Disk button Browse for skynet.inf Hope that makes DVBDream work ![]() | ||
| | #13 | |||
Anymore idea's | |||
| | #15 | |||||
From the FAQ:
| | #16 | ||
| Member Join Date: 08-06-2007 Location: tunisia
My System: nothing special , just beginner | i had the same problem and its working fine now , dont bother formatting ur pc m8 , ur device is fine and your driver as well , just download dvbdream from its original source and here`s the link _http://www.dvbdream.org/release/dvbdreamsetup_v14i.exe | ||
| | #17 | ||
| Member Join Date: 12-06-2008 Location: Italy
My System: TV on Mac | Forget about Progdvb completely! Do yourself a favor! What a rip off and shame of software industry! And definitely don't buy it (as I have done....)!, no CI support, no PIP, no HD (even though have registered their codec), doesn't tune into all channels, doesn't allow you to manually scan / add, Takes ages to clean uninstall (writes files all over) Don't clog your hard drives! | ||
