DVB Video Capture? | |
| Specialist Contributor Join Date: 29-07-2003 Location: Chorley, Lancs
My System: Innovative, Diseqc Motor, 80cm dish |
Hi All A bit of a stab in the dark this, but anyway... I have just bought an NEC DVD+RW drive which came with nerovision dvd authoring software. When i capture video from my skystar2 using progdvb and try to import into nerovision, it reports that this is not a standard mpeg2 stream. Now i obviously dont when to spend hours transcoding etc, is there any other better/flexible capture sofware available for the skystar2. I think the main downfall being i am tryin to record an encrypted video stream. Any Ideas? cheers FILE INFO File: 2.32 GB (965 MB), duration: 1:55:28, type: MPG, 1 audio stream(s), quality: 76 % Video: 859 MB, 6000 Kbps, 25.0 fps, 720*576 (16:9), MPG2 = MPEG 2 (SVCD/DVD) Audio: 105 MB, 128 Kbps, 48000 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0] Last edited by homerjay; 28-11-2003 at 04:20 PM | ||
Similar Threads | ||||
| HDTV Primer | spiney | High Definition Receivers transmissions, satellite and Terrestrial | 0 | 16-01-2006 12:42 PM |
| Video Capture Cards | malcolm | Computer Discussion | 6 | 25-02-2005 12:30 PM |
| SKy+ installed but now I have a video problem? | rapterman | Sky+ and PVR Systems | 3 | 03-02-2004 08:42 PM |
| Free premiership video clips from '3' | net1 | Mobile phone/GSM chat | 0 | 14-08-2003 07:40 PM |
