Sky Star HD...dilema. | |
| Member Join Date: 18-03-2007 Location: london
My System: not yet |
hallo guys... I have bought a Sky Star HD card and tryied for three weekes now to make it work.My dish is an 1.1m Triax and the motor is a Stab diseqc 1.2 H-H 100... Now the problem that I have is I can`t make my dish moving from one satellite to another.The prog viewer I use is My Theatre v3.38 and I do have reception on 13E Hotbird .If anyone PLEASE give me some answers about plugins I have to use ... are the same ones working for Sky Star 2 as well for Sky Star HD.What do I need to do?Thank you. | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Well, no-one has been able to help you in your earlier thread posing the same question, so it seems likely that not many people have a Skystar HD card, or more to the point, use it with your viewer to operate a motorised dish. Llew | ||
My System: not yet | Thank you Llew for your attention... But I`m a beginer, I don`t know how to do that.My viewer is My Theatre v3.38 or the original one from technisat TechniSat TV Center 1.0.7.2.From here I`m lost where and what to use, which driver and how, wich plugins and how to use.I`ll keep looking around anyway.Thank you very much.Could you recomand me a good viewer and the plugins I need?.. | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | I can't justi 007 for the Skystar HD card, as I don't have that one, only the basic Skystar2. Presumably it uses different drivers, which may or may not work with certain viewers. As you say, best to wait and hope for an answer here or do a search elsewhere. Regards, Llew | ||
