Tuner4PC - satellite manager | |
| Member Join Date: 21-04-2007 Location: Russia
My System: 1.2m dish |
Tuner4PC is a program which allows to organize the satellite Internet on your computer without installation the manufacturer software. Tuner4PC have simple and intuitively interface + good functionality. Tuner4PC effectively works in Windows Vista and supports a plenty of the equipment on WDM and BDA drivers. The program has the following features: - supports the following satellite receivers -Aver DVB-S -BroadLogic 2030/1030 -GeniaTech DigiStar DVB-S PCI -Kworld DVB-S 100 совместимые (Vstream,Dynavision...) -ADS Tech - Instant TV DVB-S (Part Number: PTV-341) -LifeView FlyDVB -Netcast DVB -Pinnacle PCTV Sat (driver >=260) -Technisat SkyStar 2 PCI/USB or SkyStar 3 PCI/USB -Telemann Skymedia 300 DVB (not official) -TwinHan совместимые (VisionDTV,Power Color,Chaintech,...) -WinTV NOVA (Budget) PCI/USB -DVBWorld USB2.0 DVB-S, DVBWorld DTV (PCI-Sat) -Acorp TV878DS/DS110/DS120 -Nextorm NBS240/NSC120 -Q-Box USB2.0 -MatchBox USB2.0 -Cards with BDA drivers - a built-in statistics module allowing you to quickly get information about the amount of data for a satellite Internet service provider by days - a multilingual interface (it is possible to add your own language module) - an intuitive wizard allowing you to easily configure the tuner for a particular provider - supports all satellite boosters (Slonax, Globax, Sprint and etc.) - OpenVPN, VPN support - it is possible to easily change the MAC address of a subscription on the software level without changing the MAC address of the card on the hardware level - automatically starting the last subscription - displaying the quality/strength of the signal from the satellite provider - displaying the speed of receiving data from the satellite provider a flexible subscription manager Official site: http://www.skygrabber.com | ||
