Vplug wonderful | |
| Member Join Date: 20-04-2006 Location: Lisbon
My System: 1,20m Nokia dig |
Could someone please explain what is vPlug for? I heard this is wonderful, but dont know what it does. I use a satellite card on my PC, and I'm looking for something to unscramble channels. Will vPlug do that? Is vPlug intended to work only with a standalone receiver or CAM? Please advise. Thanks | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Yes, use it as a plugin to your DVB software (progdvb etc). You'll need an emulator (s2emu) and latest k*ylists in the same folder. Can be used with a receiver with a LAN connection to your PC and a server program (SBCL) on your PC. Llew | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Don't need a receiver if you have the card, whether using vplug or any other plugin (yankse etc.) Llew | ||
