skystar2 | |
| Member Join Date: 02-05-2007 Location: malta
My System: skystar2 |
hi all i would appreciate if someone can help me out... this problem happened all of a sudden.. last week i was watching progdvb and i got skystar2 as a card. then the next day i tried to watch progdvb again but it was telling me device not started. i tried to install drivers again but same thing. i re-installed windows but no luck... if someone can help me out i really appreciate... thanks all!! anyone who can help me add me on msn: removed@gmail.com Last edited by Topper; 02-05-2007 at 09:28 PM Reason: Email address removal | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
Post moved. Next time start your own thread don't tag it on to an archive from over two years ago
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| Section Leader Join Date: 07-07-2006 Location: INDIA
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | This happen may times, with progdvb, its natrual for it, many peoples ask the problem u difined as. The simple answer is kick start ur dvb card, with other dvb software combining with prog dvb. It will start automatically .
__________________ | ||
My System: skystar2 | so if i remove progdvb and install for example alt dvb will it work? even in device manager the skystar2 card is shown in yellow. | ||
| | #5 | ||
| Folding*home Join Date: 23-02-2006 Location: Madeira
My System: [ Relook 250S ] | If it shows in yellow in device manager you need to install the card again or at least upgrade the driver. You cam just upgrade the driver to the same old version you had previously, well, worked for me... Try to get the latest driver, it's always better (should be anyway).
__________________ ![]() When people ask me what I think, I tell them: "I think all of the meat around the pig's ass is pork." | ||
