How Many Satellites We can Receive with Dish Tv DishWant information about how to receive certain satellites on the Indian Sub continent, this is the section for it. | |
| SAT HUNTER Join Date: 20-08-2007 Location: india
My System: One 12 Feet Heavy Antenna, one 10 Feet Double Rib Antenna Dreambox Dm500S, DM 7025. HD Receiver,Envision, Eurostar receiver, 4 Dual LNBS, 5 PFA Lnbs |
HI, How Many Satellites We can Receive with Dish Tv Dish Can we receive ST1+DD Direct+Dishtv on Same 60 Cm antenna using multiple LNBs | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Using offset lnb's on any dish is always a compromise because the lnbs set up off the main focal axis always receive a weaker signal than the prime focus. At the end of the day it all depends on the downlink power of the satellites as received at your location. Here in Europe we normally recommend 80 cm dishes for multi satellite reception to ensure the maximum amount of signal collection, but try it and see | ||
| Regular Member Join Date: 07-07-2006 Location: INDIA
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | If you want to hunt as many as,...! Then you could have a bigger one...! YOu would be happy . If you are staying with exiting one..! Few sats ...! YOU may miss few TPS Tooo...! | ||
| Regular Member Join Date: 19-06-2007 Location: Bangalore, INDIA
My System: 6 Feet solid dish (Link), dual LNBF, Beetel Receiver, receiving Asiasat2, 3S, NSS6 and DD Direct | Hi, Receiving Zee Dish, DD-Direct and ST1 in a 60 Cms dish. Even you can get Tata Sky @ 83 deg in the same dish... DD-Direct and Zee Dish one LNB is required. For ST1 you have to add one more LNB and for Tatasky one more required. Check the picture | ||
| | #5 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Good Work bro...! Looks you have modified your dish alot. | ||
| | #6 | |||
| Member Join Date: 10-01-2007 Location: Vadakuthu, India
My System: 16 feet dish, Humax, Yuri LNBF |
He didn't modify anything. Just see the photo carefully. You should ask who was the real person who tried that. | |||
| | #7 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | No problem bros, Be cool...! Real persons can teach other persons. | ||
| | #8 | |||
My System: 6 Feet solid dish (Link), dual LNBF, Beetel Receiver, receiving Asiasat2, 3S, NSS6 and DD Direct | Any how i tried in my 6 feet dish. One picture shows Ku-Band dish receiving DD-Direct (93.5) and Zee Dish (95) Another Position of KU-Band receiving ST-1 (88) Even i tried and got TataSky (83) in the same dish | |||
| | #9 | |||
My System: 6 Feet solid dish (Link), dual LNBF, Beetel Receiver, receiving Asiasat2, 3S, NSS6 and DD Direct | It's not "nothing to get in 88 deg" There are two really good Tamil Radio Channels from Sri Lanka along with test cards for tamil channels in srilanka. and in 95 deg "Kalaignar TV" from tamil nadu is FTA and superb channels. However these two locations are good for Tamilians and rest of them it's waste. | |||
| | #10 | ||
| Member Join Date: 06-03-2008 Location: india
My System: I am using the dish tv setup |
Excellent work dude, never thought of this concept before. I have a query here. I am having dish tv connection (90 cms dish). If I go ahead and use the C-band LNB and connect it the existing dish, will I be able to receive channels from Insat 2E. | ||
| | #12 | ||
| Member Join Date: 01-08-2008 Location: rohini,delhi
My System: intel core2duo ,1GB RAM with 160 GB hard disk plus dish tv | hello frnds, Can i receive abs-1 in delhi and how many channels can i receive if i use a 90 cm ku band dish antenna Thanks | ||
| | #13 | ||
My System: One 12 Feet Heavy Antenna, one 10 Feet Double Rib Antenna Dreambox Dm500S, DM 7025. HD Receiver,Envision, Eurostar receiver, 4 Dual LNBS, 5 PFA Lnbs | @Praveen all the channels of both SOuth & North beams will come in 90 CM | ||
| | #15 | ||
My System: One 12 Feet Heavy Antenna, one 10 Feet Double Rib Antenna Dreambox Dm500S, DM 7025. HD Receiver,Envision, Eurostar receiver, 4 Dual LNBS, 5 PFA Lnbs | sent you the answer if you face any issue do let me know | ||
| | #16 | ||
My System: intel core2duo ,1GB RAM with 160 GB hard disk plus dish tv | thanks bro , i hv got your reply , i hv one more doubt that (1)can i use a 6ft prime focus dish for receiving ku as well as c band channels of yamal201 and abs-1(2) can i use a 4/6ft offset dish antenna for receiving ku as well as c band channels and also if i want to receive ABS-1 / YAMAL201/YAMAL 202 on the same dish what i hv to do.plz help. what can be the approximate cost for a 4ft and 6ft dish since we are new and don't know the approx cost. thanx once again | ||
| | #18 | ||
My System: intel core2duo ,1GB RAM with 160 GB hard disk plus dish tv | thanks, what will be the overall cost for lnb and receiver .how can i put two diifferent lnb's for c/ku band channels on this 6ft prime focus dish.if i put them on this .can i receive both ku/c band channels if i focus it to yamal201 as this satellite has both ku as well as c band channels on it. | ||
| | #19 | ||
My System: One 12 Feet Heavy Antenna, one 10 Feet Double Rib Antenna Dreambox Dm500S, DM 7025. HD Receiver,Envision, Eurostar receiver, 4 Dual LNBS, 5 PFA Lnbs | YAMAL 201 C band will come on 180 CM but Ku will not come I have already tested the same. Go to Lajpat rai I check FTA Cheap receivers are 500 rs KU LNB 120 RSC band LNB 300rs | ||
| | #20 | ||
My System: intel core2duo ,1GB RAM with 160 GB hard disk plus dish tv | thanks bro, i will go to lajrat rai mkt on 23th dec, but before that i want to confirm that will i be able to receive yamal 201 ku band channels.what will be the right option i should go for 120cm ku band dish or a prime focus dish of 180cm.since i want to receive channels from abs-1 and yamal 201 especially the fashion related channels and other animated channels.what is the approx cost of 120 cm ku dish antenna so that we can ask there. | ||
| | #21 | |||
| | #23 | ||
| Section Leader Join Date: 10-05-2007 Location: north west india
My System: coship receiver 2000,Dreambox 500;2 ku3cband dishes of 2,4,6&8feet,amd 64 pc with 1GB ram usb tv tuner card | Those who are tired of reception problems due to multi satellites on single dish may explore the option of bringing another dish.A dish for a satellite is the classic option for stable reception. | ||
| | #24 | ||
My System: One 12 Feet Heavy Antenna, one 10 Feet Double Rib Antenna Dreambox Dm500S, DM 7025. HD Receiver,Envision, Eurostar receiver, 4 Dual LNBS, 5 PFA Lnbs | HI Praveen, BAD NEWS ... Now no stock available in Market for 180 CM... Earlier it was sold the cheapest Quality dish with universal brand now that is also out of stock. If you have anyone known in south india tell them to send 1 for u... There many Quality and brands are sold. Thanks to all members | ||
| dish, receive, satellites |
