Need advice how to use SUNDIRECT outside India ---> MalaysiaWant information about how to receive certain satellites on the Indian Sub continent, this is the section for it. | |
| Member Join Date: 12-09-2008 Location: Malaysia
My System: SUNDIRECT DTH only beb... | Hi all, I bought SUNDIRECT dish from India and take back to my country Malaysia, I need someone help to guide me how to align properly in order to get the signal. Let me explain something, I had activate and used this decorder in India before take back to Malaysia. The error shown : E48 No signal & E52 Searching for signal By using the _http://www.n2yo.com/?s=30793 I manage to get the azimuth and elevation at my present area, but still can't received the signal. My current location: Malaysia Sat: INSAT4B Azimuth : 232.3 Elevation : +80.09 Another my bad time was I left the remote control at India and it on way to Malaysia not sure when I will received ! But I confident my previous setting in India (done by SUNDIRECT installer). May I need to change any setting in STB ? I really apperieciate if someone able to help me ! Thanks in advance ! | ||
| Last edited by HB13DISH; 12-09-2008 at 02:35 PM. Reason: Deactivated live link to URL | |||
| SAT HUNTER Join Date: 20-08-2007 Location: india
My System: One 12 Feet Heavy Antenna, one 10 Feet Double Rib Antenna Dreambox Dm500S, DM 7025. HD Receiver,Envision, Eurostar receiver, 4 Dual LNBS, 5 PFA Lnbs | What size dish you are using to receive the signal I am not sure if yu can receive the signal theer in malaysia. I think you need atleast 180 to 200 CM antenna with Primefosucs KU lnb to receive this satellite. As far as remote you can use the same STB. as SUn is MPEG4 you wont get a decoder easily. | ||
My System: SUNDIRECT DTH only beb... | Hi, I'm using 60cm dish as what SUNDIRECT used, in Malaysia we not allowed to use external DTH except our local ASTRO (very expensive and not good.) I have a friend in Burma(Ranggon) using TATAsky with same 60cm dish he able to receive all channel from India...I'm not sure whether I able to receive or not with this SUNDIRECT ? If you recommend to bigger dish...i can't since i cannot get and heavy penalty in Malaysia if we use personal dish .... I manage to bring in this DTH from India last month....really hope able to use !... Base on the INSAT4B location it closer to Malaysia and the next sat was Measat3 (used for ASTRO Malaysia DTH provider) In Malaysia it been monopoly only by 1 company....so no much choice and expensive ! Pls help ! Any setting in STB will help me ? I'm awating for my SUNDIRECT remote control at least can play around with my luck ! Shaik | ||
My System: One 12 Feet Heavy Antenna, one 10 Feet Double Rib Antenna Dreambox Dm500S, DM 7025. HD Receiver,Envision, Eurostar receiver, 4 Dual LNBS, 5 PFA Lnbs | YEs you can do one thig better call some technician to tune your dish to the satellite if you get success that it would be great | ||
| | #5 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Sun Direct operates on the Indian beam which is a spotbeam onto the Indian subcontinent _http://www.lyngsat-maps.com/maps/in4b_india.html Now according to that officially there is no coverage whatsoever into Malaysia, but we know the satellites often have better coverage than the official maps. Extrapolating the drop off from that map (which is complete guesswork and probably inaccurate) Id say you will need something well over 1m in diameter. You say you cant have a dish that size, therefore you cant have Sun Direct. | ||
| | #6 | ||
My System: SUNDIRECT DTH only beb... | Hi Anologuest, let say I'm using more than 1metre dish what kind of LNB I suppost to use ? KU or C band ? Just for you info, few months a go I went to Burma (Ranggon) notice one of my friend using TATAsky there and he using original 60cm dish in Burma and he able to received all the channel. I also think the same concept as what u had claimed but not sure since not much knowledge on Sat dish... I really hope if I can get some channel with my current gadgets eg. 60cm/sundirect dish I will more than happy ! but my problem is no remote control so adjust any setting in the STB... Are there any potential if I change any setting on STB will received some channels ? | ||
| | #7 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Sun Direct transmit in Ku band. I have no idea about the possibilities of the receiver, although many boxes these days are tied to the service they are originally designed for. Its a certainty though if it will work away from Sun Direct that you will only get the free channels from other satellites on it. As for the lack of remote control - many boxes have very low functionality without the remote! | ||
| | #8 | ||
| Section Leader Join Date: 10-05-2007 Location: north west india
My System: coship receiver 2000,Dreambox 500;2 ku3cband dishes of 2,4,6&8feet,amd 64 pc with 1GB ram usb tv tuner card | If you manage to get an ordinary FREE to Air receiver than fix your dish to proper location,the setting in receiver are not to be disturbed prior to that. | ||
| | #9 | ||
My System: SUNDIRECT DTH only beb... | Hi all I just received my sundirect remote control, after i enter the dish configuration the 2nd bar still show 0% compare to first bar shows 97%, I already tune tyhe dish pointing to the required position but no signal at all. I beliave I should received at least few % to confirm my tuning is correct. Azimuth : 232 Elavation : 79 I'm currently using 60cm dish...pls advice any chances to get the signal if i bought bigger dish or what is the recemended dish size and why I totaly nor received any signal ? Pls help.... | ||
| | #10 | ||
| Member Join Date: 28-04-2007 Location: Brunei
My System: 6' Sattelite dish with Topfield digital receiver |
Hi, i am staying in Brunei (near East Malaysia) and i have tried the same thing like you by bringing in Dish TV decoder sometime back, I already have 2 meter Dish here (i am using to view free to air channels in C- band), my technician here tried his best but unable to get the signal for dish tv (NSS6 satellite). The chances are very remote to get the signal from the spot beam also bear in mind Astro in Malayasia will lose it's customers if SUN Direct channels can be viewed in Malaysia hence i don't think you will be able to view the channels in Malaysia. | ||
| | #11 | ||
My System: SUNDIRECT DTH only beb... | friend, Thanks, My relatives in Dubai able to receive TATAsky/SUNDirect with 5ft dish C band....some of the ask us to perform the tuning such way : removed url linking to another forum But now i get 4 ft dish and c band LNB to shot the bird...but no one expert here...that is the proble... | ||
| | #12 | ||
My System: coship receiver 2000,Dreambox 500;2 ku3cband dishes of 2,4,6&8feet,amd 64 pc with 1GB ram usb tv tuner card | Bro sshaik,The signal of ku appears to be concentrated to India.Pl check whether you are able to receive ku signals from the satellite with the help of FTA receiver,replace c band LNB with ku LNB and check.If you are able to receive11570 V27500 DD channels,then ku is receivable in your location,otherwise no hope. | ||
| | #13 | ||
| Member Join Date: 09-09-2007 Location: My
My System: DM500 | hi,shaikey boy the no way to get this SUNDirect in Penang Malaysia if u want to try u need 600cm disk thats impossible to buy the disk in malaysia maybe u can borrow it from ASS Teroh | ||
| | #14 | ||
My System: DM500 | Hi,Shaik This is the list of Satellite u can get in Penang Malaysia Satellite Beam/EIRP (dbW) Dish size (cm) TV Radio Data EVA AZI LNB 49.0E C-Band: YAMAL 202 YAM202CB 40 120 33 1 1 31.1° 265.7° 83.2° 57.0E NSS 703 NSS703EH 35 300 20 1 0 39.9° 264.4° 82.3° 62.0E INTELSAT 902 INT902CG 34 360 6 1 0 45.4° 263.3° 81.5° 64.0E INTELSAT 906 INT906CG 36 240 3 0 0 47.6° 262.8° 81.1° 64.0E INTELSAT 906 INT906EH 41 120 2 2 0 66.0E C-Band: INTELSAT 704 INT704EH 36 240 2 15 3 49.8° 262.3° 80.7° 68.5E C-Band: INTELSAT 7.10 INT007CV 30 570 16 2 0 52.6° 261.5° 80.0° 68.5E C-Band: INTELSAT 7.10 INT010CH 32 450 134 10 2 68.5E C-Band: INTELSAT 7.10 INT010CV 35 300 104 107 7 70.5E EUTELSAT W5 EUT0W5S1 45 90 16 12 0 54.9° 260.8° 79.4° 74.0E C-Band: INSAT 3C INS02ECW 38 150 2 0 0 58.8° 259.4° 78.2° 76.5E TELSTAR 10 TEL010CG 41 120 119 59 11 61.6° 258.2° 77.0° 78.5E THAICOM 2.5 THA002CR 32 450 9 3 0 63.9° 257.0° 76.0° 78.5E THAICOM 2.5 THA002KU 51 55 20 0 0 78.5E C-Band: THAICOM 2.5 THA002CR 32 450 2 0 0 78.5E C-Band: THAICOM 2.5 THA005CR 34 360 88 11 1 83.0E C-Band: INSAT 2E.3B.4A INS02ECW 38 150 36 0 0 68.9° 253.4° 72.6° 83.0E C-Band: INSAT 2E.3B.4A INS02ECZ 39 135 14 0 0 83.0E C-Band: INSAT 2E.3B.4A INS04ACB 41 120 54 2 0 87.5E CHINASTAR 1 CHI001CB 39 135 9 6 0 73.8° 247.8° 67.2° 88.0E ST 1 STC001CB 40 120 16 7 0 74.4° 246.9° 66.4° 88.0E ST 1 STC001K1 52 50 10 1 0 91.5E MEASAT 1.3 MEA001KM 56 38 33 0 3 78.0° 239.0° 58.6° 91.5E MEASAT 1.3 MEA003KI 48 70 163 36 40 91.5E C-BAND: MEASAT 1.3 MEA003CG 36 240 22 24 0 93.5E C-Band: INSAT 3A.4B INS03ACE 30 570 6 2 0 79.9° 232.0° 51.7° 95.0E NSS 6 NSS006SE 52 50 8 6 0 81.3° 224.8° 44.5° 107.7E CAKRAWARTA 1 CAK001SB 43 100 70 19 0 79.2° 125.1° -54.6° 108.0E C-Band: TELKOM 1 TEK001CB 42 110 61 0 1 78.9° 124.0° -55.6° 110.5E SINOSAT 1 SIN001CB 40 120 1 20 0 76.4° 116.9° -62.6° 113.0E C-Band: PALAPA C2 PAL0C2CA 35 300 1 1 0 73.8° 112.1° -67.3° 113.0E C-Band: PALAPA C2 PAL0C2CE 37 180 24 8 4 115.5E CHINASAT 6B CHI06BCB 38 150 123 99 3 71.0° 108.6° -70.6° 120.0E THAICOM 1A THA01ACR 32 450 6 1 0 66.0° 104.4° -74.7° 125.0E SINOSAT 3 SIN003CB 37 180 1 0 0 60.4° 101.3° -77.5° 128.0E JCSAT 3 JCS003CA 36 240 34 42 0 57.0° 99.9° -78.8° 134.0E C-Band: APSTAR 6 APS006CB 40 120 21 8 1 50.3° 97.9° -80.5° 138.0E C-Band: TELSTAR 18 APS005CB 40 120 29 10 0 45.9° 96.8° -81.4° 146.0E AGILA 2 AGI002CA 38 150 31 5 6 37.0° 95.1° -82.6° 148.0E MEASAT 2 MEA002KM 54 45 70 2 2 34.9° 94.8° -82.9° 166.0E INTELSAT 8 INT008CH 35 300 82 12 0 15.7° 92.4° -84.2° 166.0E INTELSAT 8 INT008CV 35 300 68 34 8 169.0E INTELSAT 2 INT002CO 30 570 3 0 0 12.6° 92.1° -84.3° 180.0E INTELSAT 701 INT701NW 35 300 1 0 0 1.5° 90.9° -84.6° | ||
| | #15 | ||
My System: SUNDIRECT DTH only beb... | Currently I'm using 6feet dish and able to gell all free channel but I feel i might need to purchase good KU LNB in order to get the signal ???? | ||
| | #16 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | | ||
| | #17 | ||
My System: coship receiver 2000,Dreambox 500;2 ku3cband dishes of 2,4,6&8feet,amd 64 pc with 1GB ram usb tv tuner card | If you are able to get free channels from the satellite,there is guaranteed reception for the ecrypted channels as well,provided proper equipments are installed. | ||
| | #19 | ||
| Member Join Date: 04-12-2008 Location: KL
My System: Dish TV DTH |
Hi sshaik , i have dish tv india stb and i suppose it works with nss6, can u tell is there any way to use it in KL. or can u tell me if i can still receive FTA free to air channel with this box... i m novice in this Thanks | ||
| | #21 | ||
| Member Real name: Ahmed Join Date: 19-09-2009 Location: UAE
My System: INSAT 4B Azimuth : 118.46 elevation : +38.5 Latitude: 25.23° Longitude: 55.28° | HI ANALOGUESAT i hav a 10 ft C band dish i would be pleased to know if i can use it for SUN DIRECT DTH.. THNXX IN ADVANCE | ||
| | #22 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | According to an earlier post a 5 foot dish can be used in Dubai for Sun Direct. Sun transmit in Ku band not C-band, so if your dish is a C-band mesh dish it wont be suitable. If its a solid dish then you should be ok if you can find a suitable lnb for it. | ||
| | #24 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | You should be able to if you find a suitable lnb for it. | ||
| | #25 | ||
| Member Join Date: 12-10-2009 Location: Malaysia
My System: Sun Direct | Hi Guys, I recently buy the sun direch DHT, and cuold get the signal in my place KL, Malaysia, anyone in malaysia using it, can you all guide me how to get the signal and channel in malaysia, SShaik, Your info is most appreciated,Please help me guys.... | ||
| >, advice, india, malaysia, sundirect |
