Dish size required to get sundirect signal in south east asia (North Malaysia)Want information about how to receive certain satellites on the Indian Sub continent, this is the section for it. | |
| Member Join Date: 12-09-2008 Location: Malaysia
My System: SUNDIRECT DTH only beb... | Hi all, need you guys expert to advice how big dish i suppose to used in order to get sundirect signal from INSAT4B. Currenly I'm using 60cm dish (KU band) but totally unable to received any signal at all. I plaining to get C band but no idea the dish size. As per lyngsat.com, I might able to received the signal unless I used 4ft dish but I'm not sure I able to received all SUNDIRECT channel ? Pls advice What I have now: 60cm dish SUNDIRECT STB with simcard refered to : _http:/www.lyngsat-maps.com/maps/in4b_ecc.html Pls help... | ||
| Last edited by HB13DISH; 25-09-2008 at 06:42 AM. Reason: Deactivated Live URL link | |||
| Section Leader Join Date: 10-05-2007 Location: north west india
My System: coship receiver 2000,Dreambox 500;2 ku3cband dishes of 2,4,6&8feet,amd 64 pc with 1GB ram usb tv tuner card | Theoratically it seems possible with 6 ft dish,I recommend 8 ft solid dish,however,ku reception is always mysterious;sometimes it spills over to those area not covered at all like hotbird being received in India,many other times it has no reception in the area supposedly covered. I advice not to take the maps for granted. | ||
My System: SUNDIRECT DTH only beb... | Hi Srei, recently I bought 4ft dish/FTA STB and C band LNB. Now I able to get the signal using this configuration, but not sure what and how to received usung my SUNDIRECT STB ? Need KU Band LNB ??? or something else, with my current C band/4"/FTA STB, I able to get all Doorshan channels (very good quality)... | ||
| SAT HUNTER Join Date: 20-08-2007 Location: india
My System: One 12 Feet Heavy Antenna, one 10 Feet Double Rib Antenna Dreambox Dm500S, DM 7025. HD Receiver,Envision, Eurostar receiver, 4 Dual LNBS, 5 PFA Lnbs | In SUNSTB you cannot receive any other TPS as in that STB entering TP is not allowed | ||
| | #5 | |||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue |
Is it a solid dish or a mesh dish? If its mesh its not suitable for Ku band,. | |||
| | #7 | ||
My System: coship receiver 2000,Dreambox 500;2 ku3cband dishes of 2,4,6&8feet,amd 64 pc with 1GB ram usb tv tuner card | Bro sshaik,The signal of ku appears to be concentrated to India.Pl check whether you are able to receive ku signals from the satellite with the help of FTA receiver,replace c band LNB with ku LNB and check.If you are able to receive11570 V27500 DD channels,then ku is receivable in your location,otherwise no hope. | ||
| asia, dish, east, malaysia, north, required, signal, size, south, sundirect |
