Help required to receive Paksat
Want information about how to receive certain satellites on the Indian Sub continent, this is the section for it.
Old 06-06-2009   #1
My System: 8ft mesh-asiasat3,2-measat-thaicom-st1-telestar-abs-pas10-yamal@49
I was in southIndia. i could get only the vertical polarisation channels and two channels only from horizontal.so i needs help to recieve all the channels from c band horizontal Beam of Pak-sat@38
billa is offline   Reply With Quote
Old 06-06-2009   #2
please tell us which type of feedhorn you have
Normal feed horn or Universal feedhorn ( vertical+Horizental)
gunakarrout is offline   Reply With Quote
Old 06-06-2009   #3
I have only the normalfeed horn
Old 20-06-2009   #4
Section Leader
srei's Avatar
My System: coship receiver 2000,Dreambox 500;2 ku3cband dishes of 2,4,6&8feet,amd 64 pc with 1GB ram usb tv tuner card
The footprint picture of the satellie _www.lyngsat-maps.com/maps/pak1_north.html shows the signals do not reach to extreme south India,it seems the size of dish requires to be increased for C-band.
srei is offline   Reply With Quote
Old 24-06-2009   #5
Sir I could gt 12channels from ver and 2 channels from horizontal....
Ver polarisation channels includes Value Tv,Vibe.......Etc.
Hor pol Channels includes sindh&sindh news.....I could recive these with 8ft mesh dish,,
Old 25-06-2009   #6
Section Leader
srei's Avatar
You are receiving the transponders from what we may call technically as fringe reception,generally vertical polarity is easier to get in case of fringe reception.
Old 26-06-2009   #7
wat does fringe reception means sir.......But I could get 2channels from Hor pol also.
Old 26-06-2009   #8
Amo Amas Amant Admin
Topper's Avatar
Well
Fringe reception is roughly defined as unpredictable signal reception on the edge or even outside of the predicted footprint map
_http://www.lyngsat-maps.com/maps/pak1_north.html
The area defined in blue or even outside of that area would be categorised as fringe reception, but of course fringe reception is also to some extent predetermined by your own dish size
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 27-06-2009   #9
But I can get the signal above 60% .Can I get Yamal@90* satellite with 8ft mesh.
Old 27-06-2009   #10
Section Leader
srei's Avatar
Extremely difficult,here in Rajasthan 80% of the transponders are received.You are in Kerala,where the signal is almost dead,however,a bigger dish of 10 Ft.may enable you to find some transponder,that too not in a cosistent way.
Old 03-07-2009   #11
Can U post me the stronger frequency in that satellite
Old 03-07-2009   #12
Section Leader
srei's Avatar
Yamal 202 at 49.0°E would be a better option for you.Get Ren TV at 3706 L 15550,If you are easily receiving the satellite then report the quality of reception.
Old 06-07-2009   #13
I'm already reciving that satellite and I could able to get all channels from these satellites
Old 07-07-2009   #14
Section Leader
srei's Avatar
3553 L TMT 20000,you would get any of four turkistan channels.Keep the polarity of LNB as it is.
Old 07-07-2009   #15
ok.........Can I get any Ku band satellite with 8ft mesh dish.....
Old 09-07-2009   #16
Is there any KU band satellite In which I can recive with 8ft mesh in our location
Old 11-07-2009   #17
Section Leader
srei's Avatar
Certainly not for Yamal@90,its ku is receivable upto extreme North India.
Old 13-07-2009   #18
I m not taking about yamal only.I want the details of all KU band satellite which I can recive with 8ft mesh dish
recive, required
