Dish TV in Dubai - questionsWant information about how to receive certain satellites on the Indian Sub continent, this is the section for it. | |
| Member Join Date: 11-09-2007 Location: Dubai
My System: none- newbee |
Hello All, I have Dish TV (Zegna receiver) in Dubai and it works fine. I have moved residence and in the process of re-installing the Dish. I would like to know the following as a matter of interest.
Hamps Hump | ||
| Section Leader Join Date: 10-05-2007 Location: north west india
My System: coship receiver 2000,Dreambox 500;2 ku3cband dishes of 2,4,6&8feet,amd 64 pc with 1GB ram usb tv tuner card | Except the cable,all other things you have had should be working fine in your new home.Actually there is nothing particular like good or best quality these days,due to competition and technology advancement. I purchased the best receiver I thought by spending four times the usual cost of reciever.Due to change of technology from MPEG2 to MPEG4 it is almost useless. | ||
My System: none- newbee | Hello All, I expected more replies to my post. However, since then I have researched a bit and come up with what will hopefully be a good solution. 1. I have bought a INVACOM twin LNB model TWH-031 to connect two Dish recievers - twin is 135 AED single is 85 AED 2. I bought CommScope 75 Ohm co-axial cable 60m reel - 50 AED 3. I bought 2 two way spliters (one for each reciever) - 8 AED 4. Dish size is 110cm - cost is about 100 AED 5. Cost of instalation by technician is 150-200 AED All above products are avaiable in the Knaif road area in Deira from EUROSTAR. The way I plan to set up is to connect the cable coming from the LNB to the input of the splitter and use any one of the output of the spiltter to connect to the receiver. (leave the other blank or tape it with insulation tape) I do not have a technically explanation as to why this method can be better than the others but the results are expected to better than using a in-line signal amplifier or connecting the cable directly to the reciever. I will post an update once I have the Dish fitted this evening. | ||
| dish, dubai, questions |
