Help required for :-How to configure dish for PAS 7/10Want information about how to receive certain satellites on the Indian Sub continent, this is the section for it. | |
| Member Join Date: 05-10-2006 Location: India
My System: Zenega 1006S STB + 60 cm dish. |
I am having Zenega STB and 60 cm dish provided by Dish TV. I want to configure my system to receive FTA channels of PAS 7/10 . Any one please give procedure to do so as this will also help other people of this forum to install such system. If any newbie like me wants to install such system, please raise your voice in this thread so that mastermind people of this forum let us the info as soon as possible. Regards DD. | ||
| | #2 | |||
| Specialist Contributor Join Date: 10-03-2005 Location: Kasaragod,Kerala,South India.
My System: Sat:Insat 4 B and NSS 6 Platform:DD Direct+ STB:Eurobox 9700+CI System:Celeron D 2.8 GHz,Fedora Core 6 and Windows Vista Home Premium Edition. |
For this you can browse thru Lyngsat or satco or flysat or the sat mfr. site. Then confirm that you are having the specific hardware requirements. Eg,for proper dish size. According to your EIRP values for you place from the footprints pls refer to this link. _ww.satlex.de/ Further confirm that you have the proper software reqrments like the option for your STB to add new satellites,TP,Diseqc switch option etc. If these conditioins are met you can proceed. More info are avialbale in the forum itself.Try to search and find yourself.If more details are reqrd pls PM me. | |||
Imagination is more important than knowledge... Albert Einstein | ||||
My System: Zenega 1006S STB + 60 cm dish. | Thnaks hareesh. yes there is ption in my stb for adding sat or TP. as mine dish is provided by dish tv (Zee) its size my be 75-80cm and i am living in CG based on this if you ppl can suggest me for getting any other satellite's FTA channels with these hadware. thanks in advance | ||
| | #4 | |||
| Regular Member Join Date: 07-07-2006 Location: INDIA
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S |
If you want to receiver KU band singal on pas 7/10 by through you small dish , you can abele to do it,you need a big size dish anteena, One more thing on KU band signal there 4 channels beaming India and that channels are DD Channels and 2 feed channels, and 4 to 6 empty slot channels, Its better you go for C Band signal on PAS7/10 you can abele to get 30 to 40 FTA Channels. I bet that channels are lot more better than ALL. | |||
| | #5 | |||
| Member Join Date: 14-04-2006 Location: Ghana
My System: dm 500s |
enjoy,joesat | |||
| | #6 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | | ||
| 7 or 10, configure, dish, pas, required |
