Introduction to Asia Broadcast Satellite (ABS-1 75.0 East)
Want information about how to receive certain satellites on the Indian Sub continent, this is the section for it.
Old 19-01-2008   #51
My System: INSAT 4B NSS 6 ST1 ABS 1 EDUSAT
Hi David,
you can do yourself to do the settings, check the antenna direction ***.dishpointer.com
I am receiving the channels from my 60cm dish in pondicherry.
- admin
if you have any questions call me at phone number removed
best of luck
karunagaran p
Last edited by Hareesh; 19-01-2008 at 06:59 PM. Reason: remove phone number, live links
pkgaran is offline   Reply With Quote
Old 19-01-2008   #52
Site administrator
Analoguesat's Avatar
Personal details such as phone numbers should not be posted on the forum. Only swap them by email or pm.
Analogue forever!
Analoguesat is online now   Reply With Quote
Old 21-01-2008   #53
My System: 2.4m Dish with C & Ku LNBs.
Originally Posted by Davsat View Post
Hello Senior Menbers
Do you know any dish antenna technicians in Chennai who can setup my 90 cm ku band antenna to receive ABS1 south beam. I have TVS electronics Setop box. Also I have Zenega receiver and 60 cm antenna from DishTv Network.
David
I am also from Chennai but PM is not allowed for new members See my profile and if you want you can contact me there With your above equipements you can receive that satellite very easily.
lnb15k is offline   Reply With Quote
Old 25-01-2008   #54
My System: 90 cm Antenna
Hi pkagaran
Thanks for the reply, I have visited ***.dishpointer.com which was very usefull. I will try to do allignment myself, Hope it will work for me.
David
Davsat is offline   Reply With Quote
Old 25-01-2008   #55
Hi lnb15k
Thanks alot for the reply. I was desperate in searching someone who can help me in alligning antenna with abs1, Thanks God you guys are really responsive and helpful. I will try to allign myself, Lets see whats happen....
David
Old 30-01-2008   #56
Hi lnb15k
I tried to allign but I was only able to get 50% signal but when I tried to retune it I lost that bird. Later I tried for hours but in vein. Totally hopeless
David
Old 01-06-2008   #57
My System: DishTV
please broadcast the VOA and RFA radio again on your satellite
Dear sir,
please broadcast the VOA and RFA radio again on your satellite...
jigten
Originally Posted by seanlangston View Post
Dear Forum Members,
I would like to introduce myself. I am the Senior Director of Broadcast Services at Asia Broadcast Satellite, the owner and operator of the ABS-1 satellite at 75.0 East. I have been following some of the message threads about ABS-1 (ex LMI-1) in this forum and would like to open a channel for communications with our company here.
If you have any questions about ABS-1, our services, coverage, power, or channels currently broadcast by our satellite, I will do my best to answer them.
ABS will be exhibiting at the upcoming CommunicAsia 2007 expo in Singapore from June 19 to 22, and at the planned EMEC 2007 in Karachi from July 16 to 17. If you would like to learn more about our company, please drop by and say hello.
Regards,
Sean Langston
Jigten is offline   Reply With Quote
Old 01-06-2008   #58
My System: Distributer for Fiber Glass dish anteena systems
Hi
I am in India DElhi 28.5latitude 77.7 longitude.What size of dish is required and which channels can be viewed on ABS
Regards
Vipin
vipinsatyawali is offline   Reply With Quote
Old 01-06-2008   #59
SAT HUNTER
Moradabad's Avatar
My System: One 12 Feet Heavy Antenna, one 10 Feet Double Rib Antenna Dreambox Dm500S, DM 7025. HD Receiver,Envision, Eurostar receiver, 4 Dual LNBS, 5 PFA Lnbs
for Delhi Abs KU u need 120 CM what types of fiber glass dishes u sell
Moradabad is offline   Reply With Quote
Old 28-08-2008   #60
My System: amd 4200 x2 1gb Gigabyte GA-MA78GM-S2H, dishtvDISH/FTA recvr.
Abs 1
i am in delhi. tried recieveing abs1 on my dish tv dish but was getting edusat @74 E with signal quality @ 92-93% after rotating the lnb.
But still not recieving ABS1. what do i do ?
someone pls. help...
ajayvats is offline   Reply With Quote
Old 31-08-2008   #61
My System: intel dual core with 1 GB Ram and internal media catd reader with dish tv and dd direct+
sir,
how can i receive abs satellite on my 60 cm ku band dish antenna.i am currently staying in delhi
plz help
ramakrishnan is offline   Reply With Quote
Old 31-08-2008   #62
Site administrator
Originally Posted by ramakrishnan View Post
sir,
plz help
Read post 59. You need a 120cm dish.
Analogue forever!
Old 06-09-2008   #63
Sir KU CLAMPS are special clamps with 1 Big ROD & A CLAMP to Hold multiple LNBS on same dish.
I receicve ABS1,ST1,TATA, DISHTV, 91.5 on same 60 CM dish
hi moradabad,
Now i am able to recv abs1 with 60cm dish tv dish. But 1-2 tp's only, rest have very low signal around 10-20 percent due to which the reciever is unable to find any channels..
what do i do ? pls guide..
Old 10-09-2008   #64
hello
now i am able to recieve abs1 all tp's
but want to ask one thing
is anyone observing sun outage around 10 am to 1130 am in delhi ?
my signal is dropping around these time to less than 20%
if not sunoutage, what else could be the problem ?
Old 17-09-2008   #65
anyone else getting abs1 all tp's / FTA channels on 60 cms dish in delhi ?
i am getting tp 12549 v 22000 with very low signal/disrupt viewing/ square box -pixeling.
all other tp's i am recieving with ok signal and viewing quality.
any specific lnb will do it better ? pls suggest
Old 18-09-2008   #66
SAT HUNTER
Moradabad's Avatar
Please mention the signal of All the tps & better take a Original receiver as in local chinese receivers Tuner is not good.
Try to load FTA sw in Zenega that is good receiver
Old 18-09-2008   #67
but where can i get fta s/w for zenega ??
Old 19-09-2008   #68
immi22_80's Avatar
My System: I have 6 feet dish anteena and DTH ku band dish, coship and Kaon receiver. Right now, i'm receving on my six feet dish(yamal201 90E, insant4A 93.5E, and Asiassat3s 105E c and ku band) with the help of Disec SwItch.
Hi
U need to degrade ur receiver.....
immi22_80 is offline   Reply With Quote
Old 19-09-2008   #69
Originally Posted by immi22_80 View Post
Hi
thanks
from where ? do u have any contact no / place information ?
i need to get my 2 zenega cd1004is stb's FTA
pls see my profile for email / pm.
Old 03-11-2008   #70
My System: Insat 4B SunDirect, BSNL
Hi All.,
ABS-1 Channels of South Beam, previously i was used to Get FTV and some other fashion and lifestyle channels in that direction long back, but now those channels are not available, is there any chance of getting back those channels in ABS 1 of South Beam... any new channels in that direction in the near future.. if any body have the news plz post that.....
Thanks..
rvinmurthy is offline   Reply With Quote
Old 02-12-2008   #71
My System: LMI 75E, winxp
Hi, we are tring to get ABS1 75E beam 6A from nigeria can you pls help me with freqency and symbol rate to get signal on beam A.
Ahmad
Dear Forum Members,
Regards,
Sean Langston
baballe is offline   Reply With Quote
Old 03-12-2008   #72
Hi, seanlangston
We are tring to get ABS1 75E beam A from nigeria can you pls help me with freqency and symbol rate to get a tv signal on beam A.
Ahmad
Old 22-01-2009   #73
My System: ABS-1
ABS-1 A-Beam
Originally Posted by baballe View Post
Hi, seanlangston
Ahmad
Hi Ahmad,
If you check on the site: http://www.lyngsat.com/abs1.html
ABS-1 do not have channels on A-Beam.
vilim
vilim is offline   Reply With Quote
Old 18-02-2009   #74
My System: ku band dish, zenega cd1004s digital setup box ,p4 2.6 pro amd computer
hi sean,
welcome to this group,well v r always interest in well knowing about abs.
pratheepan is offline   Reply With Quote
Old 18-02-2009   #75
BombedOne's Avatar
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc.
But as far as I know, ABS-1 is owned by russian company, GTSS?
"GTSS offers a complex service on delivery of, processing and releasing TV programs, as well as uplink based on GTSS’s own platform on spacecraft LMI-1 (ABS-1) and distribution through Russian and the CIS cable operators networks."
_ttp://www.gtss.ru/Products_and_Services/Broadcasting_services
BombedOne is offline   Reply With Quote
750, abs1, asia, broadcast, east, introduction, satellite
