How to view Asiasat 2 in bangaloreWant information about how to receive certain satellites on the Indian Sub continent, this is the section for it. | |
| Regular Member Join Date: 19-06-2007 Location: Bangalore, INDIA
My System: 6 Feet solid dish (Link), dual LNBF, Beetel Receiver, receiving Asiasat2, 3S, NSS6 and DD Direct |
Hi, I would like to view RTP channel from ASIASAT - 2, presently am in bangalore. i would like to know the size of dish i have to buy, receiver etc.. and can some one suggest approx cost to buy the same. | ||
| ASBO Club Member - Persona non grata Join Date: 18-06-2007 Location: BANGALORE INDIA
My System: I HAVE COLORDO RECEVER WITH 6 PRIME FOCUS FEET SOLID SHEET ANTENNA. |
U can Watch AsiaSat with 90 cm or High Dish | ||
if u face receiving asiasat2 or 3 on 90 cm Antenna contact me I will help you setting the Antenna. | ||
My System: I HAVE COLORDO RECEVER WITH 6 PRIME FOCUS FEET SOLID SHEET ANTENNA. | Thanks a Lot man you are watching Members but I am receiving Except Real Madrid Tv you will receive every channel and specially TVE,RTP,PTP,Cuba tv,RAI Tv and what the person wants is RTP I bet you in this regard. Initially I told him if you face any problem call me. and the Expences is not much only around 3500+- is required for this in Bangalore. | ||
| | #5 | ||
| Regular Member Join Date: 07-07-2006 Location: INDIA
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Welcome Andarun Bro, Get a bigger one to get all the Tps. | ||
| | #6 | ||
Hi friends, As i am going to buy the accesorries like dish antennat, lnb, feed horn, receiver etc... let me know some suggested brand and approx cost in order to buy the same. some friend has refereed that 90 cms C-Band dish is enough...but some sites like scatcodx suggeste to 360 cms dish in bangalore. kindly give me a clear picture what i have to ask in shop....? to watch asiasat 2 and 3s a dual lnb is required or not. if dual lnb required will a single receiver work | ||
| | #7 | ||
My System: 6 Feet solid dish (Link), dual LNBF, Beetel Receiver, receiving Asiasat2, 3S, NSS6 and DD Direct | Hi Siddarth, Let me know the shop where i can buy the accesorries in bangalore. As you told spending 3500 is worth installing a dish system. let me know further details for the same. | ||
| | #8 | |||
My System: I HAVE COLORDO RECEVER WITH 6 PRIME FOCUS FEET SOLID SHEET ANTENNA. | Hi, You can call me I know one Person who supplies C band Antenna Mumbai Made call me on this No *********** | |||
| | #9 | ||
Hi Siddarth, Thanks for the instant reply. let me call you today. also you suggested that a mumbai made product is there...is it the same type of dish antenna you are having. also is the guy sells entire package or only the dish antenna. let me know... I also have a doubt..as you say you are atching asiasat 2...how are the signal strength. TV5 asia is on asiasat 3s can we catch asiasat 2 and 3s on same lnb or one more lnb required. | ||
| | #10 | ||
Hi siddarth, You own a 6 feet prime dish..but you suggest me to buy a 90 cms C-and dish. will 90 cms ok to catch asiasat 2 and 3s. or i have to go upto 370 cms to catch these birds in bangalore. if you are pretty sure that 90 cms dish will serve the need. i intend to buy 90cms dish. suggest me ? | ||
| | #11 | ||
My System: I HAVE COLORDO RECEVER WITH 6 PRIME FOCUS FEET SOLID SHEET ANTENNA. | Hi Friend, I have 60 CM, 90 CM, 180 cm Antennas 1 week back I was using my 90 Cm Dual Antenna for C & Ku band for Receiving Asiasat 3 and Nss6(C and Ku combine on a 90 cm Antenna. This week I brought a new 180 cm antenna for Yamal 201/202. You cannot use a 90 Cm antenna to receive both the satellites a 8 feet Mesh Antenna will server your purpose Speciall Spacelink Antenna. That is the best in India. in 8 feet I gurrantee you u can receive both. If any doubt call me. | ||
| | #12 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Siddharth Bro, on 90cm do you got all the TPs from Asiasat 3s, From my point of view you cant get all the TPs on 90cm. | ||
| | #14 | ||
My System: I HAVE COLORDO RECEVER WITH 6 PRIME FOCUS FEET SOLID SHEET ANTENNA. | Hi Friend Can you please tell me PAS10 is on the Right side of Asiasat2/3 if its yes than Intelsat 12 or Insat 3 will be Near that. | ||
| | #15 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | C-Band: INTELSAT 7,10 is on (68.5E), C-Band: INSAT 3C is on(74.0E), INTELSAT 12 on (45.0E), They are much far. | ||
| | #16 | ||
My System: I HAVE COLORDO RECEVER WITH 6 PRIME FOCUS FEET SOLID SHEET ANTENNA. | Hi Friend, Can we receive Intelsat 7/10 on a 6 feet antenna. if yes please tell me some powerful TP | ||
| | #17 | ||
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S | Yes you can able to catch C-Band: INTELSAT 7,10 , With you dish, 4.064 GHz H, Powerful. | ||
| | #18 | ||
| Member Join Date: 25-10-2005 Location: India
My System: nss6 & pentium3 | i would like to buy c/ku combine preferably with 120cm dish capable of receiving both DD DTH and either Asiasat2 of Asiasat 3s. Where do i get it in Bangalore? | ||
| | #19 | ||
| | #20 | ||
My System: 6 Feet solid dish (Link), dual LNBF, Beetel Receiver, receiving Asiasat2, 3S, NSS6 and DD Direct | Hi Friends, Check AKASH Transmissions, wich is located at Rajaji Nagar - Bangalore | ||
| asiasat, bangalore, view |
