Buying Second-Hand dish
Thread Tools Display Modes
Old 25-06-2007   #1
My System: 6 Feet solid dish (Link), dual LNBF, Beetel Receiver, receiving Asiasat2, 3S, NSS6 and DD Direct
Hi Friends,
New 12 feet dish costs
Cheaper one - 4200 /-
moderate and economical - 5600 /-
excellent - 6500/-
second hand costs from
1600 /- to 2500/-...these dishes were atmost used 10 years by cble tv operators. once they join with MSO they prefer to sell it. is it worth buying the dish.
tell me...
whether to buy dish alone, or dish with LNB. i dont prefer buying receivers as they are old models. what about LNB any difference between the new model and the one 10 years back.
suggest me the cost to bargain.....
andarun is offline   Reply With Quote
Old 25-06-2007   #2
My System: I HAVE COLORDO RECEVER WITH 6 PRIME FOCUS FEET SOLID SHEET ANTENNA.
Hi Arun,
If you know anyone selling their 12 feet please let me know I am interested.
Siddharth
siddharthbangalore is offline   Reply With Quote
Old 25-06-2007   #3
wait for a week
Hi siddarth,
I know few guys who told me the second hand cost. mean while wait for a week, am communicating with a representative from space link . about the cost for buying a new 12 feet. let's decide soon
Old 25-06-2007   #4
Hi Arun,
The Cost of spacelink is very much around 10 to 12 thousand so we should go
for second hand
Arun by the way the rates which you have written
for a new antenna from where you got the rates thsese rates are also
good please let me know the shop/company name from
where you got these rates.
Arun Have you tried
for Yamal 202 or 201 for Ren.
Old 10-06-2008   #5
My System: DM500S, Ahtlon 64 machine
i am also interested in buying a 10 or 12 feet dish, second hand will do the cheaper the better,
Dushie is offline   Reply With Quote
Old 11-06-2008   #6
Section Leader
srei's Avatar
My System: coship receiver 2000,Dreambox 500;2 ku3cband dishes of 2,4,6&8feet,amd 64 pc with 1GB ram usb tv tuner card
Pl check that material is robust and the dish is not mutilated lest the amount spent will be squandered.
srei is offline   Reply With Quote
Old 12-06-2008   #7
My System: COMPUTER DUAL CORE TV TUNER
hi srei,
where do u stay in west india. u have dreambox where did u get from.will i receive ren tv in pune. if yes what size of dish should i buy, with lnb,receiver and what will be the cost of it. plz advice me. thanks in advance
RICH is offline   Reply With Quote
Old 05-07-2008   #8
Section Leader
srei's Avatar
You may be able to receive Ren TV in Pune,with large solid dish.For reception of most of the channels ,including Ren TV, a good quality Free to Air receiver would be enough,as Dreambox is costly,and I imported it.
Old 05-07-2008   #9
Thanks srei
hi srei,
what will be the est. cost of good fta receiver. in our local they are selling dd dth stb for rs. 850/-.i.e melbourn / pioneer stb ,will this stb work.what will be the cost of c band lnb.i went to dishpointer web: for rec. ren tv i need 150 cm dish. can i prepare mesh dish from the window net being sold in the hardware shop. will it work. plz advice. thanks in advance
Old 06-07-2008   #10
SAT HUNTER
Moradabad's Avatar
My System: One 12 Feet Heavy Antenna, one 10 Feet Double Rib Antenna Dreambox Dm500S, DM 7025. HD Receiver,Envision, Eurostar receiver, 4 Dual LNBS, 5 PFA Lnbs
Originally Posted by RICH View Post
hi srei,
For getting REN take a FTA receiver and enjoy....
Dreambox is very costly for FTA purpose
Moradabad is offline   Reply With Quote
Old 07-07-2008   #11
Crazy Techie
URPradhan's Avatar
My System: AMD PC, Skystar2 2.6D, Inverto 0.2dB Single Universal Ku-Band LNB, NUCLEUS 100cm Solid Dish
more details @ Technisat Skystar2 for sale !!!
URPradhan is offline   Reply With Quote
Old 07-07-2008   #12
vishal32's Avatar
My System: P4 WITH 512 RAM TATA SKY 60 CM DISH ANTENNA DD DIRECT+ DTH
Hello frnzs
how much a 10ft/12ft dish antenna and its setup including setbox and lnb will cost?
vishal32 is offline   Reply With Quote
Old 07-07-2008   #13
well i am myself looking for a 12 feet dish in Bangalore, if someone can give pricing and seller details for the same it would help
Old 07-07-2008   #14
SAT HUNTER
Moradabad's Avatar
Hi friends,
Let me help you:
MESH ANTENNAS BEST QUALITY BRANDED ONE
1) The 10 feet mesh is not available.
2) 12 feet Single rib heavy Aluminimum with 24 Ribs is around 14000+VAT+TAX+INSTALLATION
3) 12 Feet Double Rib Heavy Duty with 36 Ribs is 20000+VAT+TAX+Installation
4) 12 feet Double Rib very heavy professional grade is 25000+VAT+TAX+Installation
5) 16 feet Professional Grade is 35000+VAT+TAX+Installation
FIBER DISHES
1) Fiber is easy to install and good for use.
2) Rate of 8 feet is 10000
3) 10 feet is 17000
4) 12 feet is 25000
Now decide which one you need.
bye
Old 08-07-2008   #15
vishal32's Avatar
Thanks frnzs for previous response. I m in delhi and want to receive yamal 202 satellite .is this possible on 10ft dish antenna or can be possible with less than 10 ft antenna?
Old 08-07-2008   #16
SAT HUNTER
Moradabad's Avatar
NO NO My friend Vishal in Delhi you will get very good signal on 6 feet PF Dish. If need any help ping me.
Even in Delhi you will get Good signal for Yamal 201 "C " band...
Old 09-07-2008   #17
vishal32's Avatar
Thanks boss,
what will be the setup cost for 6ft dish antenna and its installation?
We have much interest in this communication field.
Old 09-07-2008   #18
SAT HUNTER
Moradabad's Avatar
Bro as you need a personal installation so better take a Chinese "6" feet Dish.
The cost is very cheap around 1800 to 2200 rs
Old 10-07-2008   #19
vishal32's Avatar
thanks bro for previous response
hello bro, how many channels can i receive from this dish antenna(india and outside).can i get all channels from yamal 201.what will be the overall cost of the(6ft) dish antenna installation(including lnb and receiver).i need this dish for my home .
Old 10-07-2008   #20
SAT HUNTER
Moradabad's Avatar
ALL TPS of YAMAL 202 & some Almost all TPS of YAMAL 201 u will receive signal around 75 %
Old 12-07-2008   #21
vishal32's Avatar
thanks boss,
from where we can buy this chinese dish antenna ,lnb and receiver?
and what will be the cost of overall setup?
Old 12-07-2008   #22
SAT HUNTER
Moradabad's Avatar
I am sorry to say this no one in Delhi sells this dishes.
We also bring from South INDIA the cost of Dish is around 2200 rs
Old 12-07-2008   #23
Section Leader
srei's Avatar
Moradabad bro,pl.test yamal 201/102 C band signals on 6 ft dish at bangalore and report in the Foorum.If yes,your dish will be marvelous to many.
Old 12-07-2008   #24
SAT HUNTER
Moradabad's Avatar
Srei 201 we cannot receive in South untill u have 10-12 feet Solid dish
Old 13-07-2008   #25
vishal32's Avatar
thanks boss ,which kind of 6ft dish antenna can we get from delhi at cheaper cost?as this will be difficult for us to buy a single dish from south?
Forum Jump
