Is Ren Tv Encrypted on Yamal 202
Want information about how to receive certain satellites on the Indian Sub continent, this is the section for it.
Old 26-06-2007   #1
My System: I HAVE COLORDO RECEVER WITH 6 PRIME FOCUS FEET SOLID SHEET ANTENNA.
Hi friends,
The data which I am getting on www.lyngsat.com/tracker/yamal202.html or other sites shows that Ren is FTA channel.
But I have seen a India satellite magzine which shows Ren is a Encrypted channel please help me....
siddharthbangalore is offline   Reply With Quote
Old 27-06-2007   #2
immi22_80's Avatar
My System: I have 6 feet dish anteena and DTH ku band dish, coship and Kaon receiver. Right now, i'm receving on my six feet dish(yamal201 90E, insant4A 93.5E, and Asiassat3s 105E c and ku band) with the help of Disec SwItch.
Hi siddarth,
how r u.....
Dear......... REN Tv is absolutely free on yamal 202@49 E.
The details are as follows;
3706L-15550
3960L-8570
3982L-4285
All above transponders are showing Ren tv on the same satellite (i.e. yamal 202@49E)
NOTE ::::::::::: Right now, i am watching all the above transponders on my six feet dish anteena with help of teflon which is inserted in the mouth of feedhorn.
sidharth u do one thing, please write which satellites are recving roght now on your six feet anteena, then i'll give u the suggestions.......
Bye
Imran
immi22_80 is offline   Reply With Quote
Old 27-06-2007   #3
HI Imran,
Thanks friend, Presently my dish is tuned to Asiasat2.
I have found the location of Intelsat 12(Ku band) I think yamal 202 is near to that.
I have purchased a FeedHorn Specially designed for Sun/Udya Tv on NSS 703 which is also in Circular polarity let me try this friday.
Hopefully I will be able to receive Yamal.Please share me Lnb position photo if you can so that I will set my lnb in same position.
1 more thing imran in the polarity section in receiver what I should set Vertical/or Horizontal.
and if you remove Teflon piece from your feedhorn what happens signal becomes week or complete signal goes....
Please reply frinend...
Regards,
Siddharth
Old 27-06-2007   #4
member91040's Avatar
My System: DISH TV,DIRECT DD+, TATA SKY,HATHWAY, NOKIA 9660S, PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S
Bro, If you remove Teflon, You wont able to get the signal. At the point of new LNB, Pls mesure F/D Ratio properly to gain high signal.
member91040 is offline   Reply With Quote
Old 28-06-2007   #5
My System: nss6 & pentium3
help me out : can Ren tv ( yamal 202 at 49.0 E) be received with 90 cm ku band dish? also do i need to turn my dish to the west and if yes how much. what is the elevation ( to receive) compared to the one for nss 6 receiving the dish tv. there is a building on the west side of my house which is taller and i think it could block the signals of many satellites including that of yamal 202.
anand kumar is offline   Reply With Quote
Old 28-06-2007   #6
Bro first a fall a big NO to KU band dish. Yamal 202 ren tv is on C-Band . Submit your Lat & Log , we will provide you AZ & EL, You must tune it towards SouthWest.
Old 28-06-2007   #7
i am in suburban area close to Bangalore. If one cannot receive c band signals of yamal 202 through 90 cm ku band dish, how is it possible to receive c band signals of other satellites (as some members have claimed in other forums to be receiving asiasat 3s signals on 90cm dish)
Old 28-06-2007   #8
Its ok bro, its a dual lnb c and ku, I am talking about the signal carring on ren tv. Its an C-Band. If you have a feedhorn and lnb, then its ok. Use bigger dish to gain all the Tps.
Old 28-06-2007   #9
thanks friend, would 120 cm dish do the job?
Old 28-06-2007   #10
Its ok, Hook C-Band and find it.
Old 29-06-2007   #11
immi22_80's Avatar
Originally Posted by siddharthbangalore View Post
HI Imran,
Regards,
Siddharth
Hi
When we removed teflon then the signal quality decreases.(for eg. if the signal quality is 60% then it goes down to 20%).
there is no need to set H or V direction in c band.
Ok, Good Luck
Here i'm sending the position of my dish. u just watch it and set ur dish accordingly.
Follwing are explanation:
Center one is yamal
near to yamal is Nss95
Neasr to nss is asiasat2
near to asiasat2 is asiasat3s
Is Ren Tv Encrypted on Yamal 202-untitled-1-copy-gif
Old 29-06-2007   #12
SATELLITE SNIFFER
mehra's Avatar
My System: Dish Tv complete equipment- 70 cm Ku Antenna, Kaon KSC-i260 MCO, Two Dish Tv OE universal LNBF, 6' C Band Antenna, Eurostar C band LNB. All attached to NSS6-ABS1-Thaicom
Question
Originally Posted by immi22_80 View Post
Hi
Ok, Good Luck
Center one is yamal
could u post a pic of the teflon inserted in the feedhorn , that makes it clear how to do it ?
mehra is offline   Reply With Quote
Old 29-06-2007   #13
Mehra Bro, Check out our few old post , You will find the pic buddy.
Old 29-06-2007   #14
immi22_80's Avatar
Dear
Good luck in ur search
Imran
Old 09-11-2007   #15
My System: NIL
Hi siddarth,
how r u.....
3706L-15550
3960L-8570
3982L-4285
Bye
Imran
Siddharth....I guess that you are in Bangalore. I am also in Bangalore. Can I get some help from someone on the following?:=>
1. Is there someone who can physically help me to get the Russian TV channels in Bangalore?
2. I have read a lot of theory. Do you know any agency or company or people who can help me out?
3. Can someone share the complete information w.r.t Bangalore?
Thanks a lot.
manicorporation is offline   Reply With Quote
Old 09-11-2007   #16
Thanks a lot.
Send me ur cell no as Private message...then I can meet you...
Old 09-11-2007   #17
Site administrator
Analoguesat's Avatar
He cant use the pm system - he hasnt been a member long enough
Trying to meet people you may meet therough the forum is a spectacularly bad idea - they might be a sex mad serial killer for all you know.
Analogue forever!
Old 10-11-2007   #18
Thanks Analoguesat,
But Still we can meet as I already met lot of people through this forum....
Regards,
Blr
Old 10-11-2007   #19
Ths Good Idea.
Old 21-12-2007   #20
Section Leader
srei's Avatar
My System: coship receiver 2000,Dreambox 500;2 ku3cband dishes of 2,4,6&8feet,amd 64 pc with 1GB ram usb tv tuner card
Friends,please remember that in order to receive ren tv, the best and the long lasting way is to receive it in c band and for proper reception you need a very good
quality dish,preferably a solid dish of 8 feet.
srei is offline   Reply With Quote
Old 15-02-2008   #21
My System: NIL
Siddharth
I could not send you my cell number. I have a request.
Can you send me a test e-mail to removed. I would give you my contact number.
Old 15-02-2008   #22
My System: NIL
I wish to see a demo on the Russian TV reception in Bangalore. Please help me out. Give me some idea on money part. How much would it cost?
Rs.4000/- etc..........Please..........
Siddharth
Can you send me a test e-mail to manikumarb on gmail account. I would give you my contact number.
Old 15-02-2008   #23
My System: DishTV DTH Zenega 1004s Receiver 90cm offset Sharp dish antenna
To watch REN TV online goto h**p://w*w.corbina.tv . You need high speed broadband connection to work smoothly ( without any buffering issue )
dspdsp is offline   Reply With Quote
The Following User Says Thank You to dspdsp For This Useful Post:
jinx1985 (16-02-2008)
Old 16-02-2008   #24
My System: NIL
Hello! Siddharth
Can you send me a test e-mail to removed. I would give you my contact number. I wish to see a demo on the Russian TV reception in Bangalore. Please help me out. Give me some idea on money part. How much would it cost?
Are you there in Bangalore?
Please do respond.
Old 16-02-2008   #25
mhku's Avatar
My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini
If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots
Fill in the vcard part of your profile if you wish members to email you.
You don't stop playing because you get old, you get old because you stop playing. Regras
Before posting in the Dreambox section please ensure you've read The Guide
Information is for educational purposes only
mhku is offline   Reply With Quote
202, encrypted, ren, yamal
