Conax CAM for DigitAlb
Thread Tools Display Modes
Old 24-08-2008   #1
Robbo's Avatar
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
Hi, I'm after a CAM that will take my DigitAlB card.
I've just bought a TM6800 and using the card slot for a CH4 HD and need somewhere to put the DigitAlb card.
I need something plug n' play or already programmed, I don't want to be messing about programming it.
Has anyone got anything I could use hanging around please, I can pay with Paypal.
Cheers
Robbo
Old 24-08-2008   #2
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband!
be sure you buy at least version 3.1 conax cam,or 4.0 the last one,older version like 2.0 does not suport Au!
after a key change,i have xcam here and the oasias,iam not sure is conax suportet on this cams or not,.i cant test without card!
reports i read on the net told that digi alb hd has misarable prictrue quality looks like an upscaled old vhs tape,can you confirm this?
Turok is offline   Reply With Quote
The Following User Says Thank You to Turok For This Useful Post:
Robbo (29-08-2008)
Old 24-08-2008   #3
Robbo's Avatar
I can't get DigitAlB HD as I have an official card and not the Kaon reciever that they make you have, so I don't know what the quality is like. The SD is alright.
I would have thought that the Oasis works.
Old 25-08-2008   #4
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.5.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card
He battled for 3 days against the Tux and won! Hurray!!
Sorry Robbo, I don't have Conax CAM lying around.
But a Technisat Conax from Sateuropa costs only 30 pounds or the Neotion Conax at 59 pounds (MPEG-2 and MPEG-4)
Could the latter help to open the DigitAlb HD channels?
Not sure which firmware versions do they have, but you can ask before you order it.
Also ask if they are both good for DigitAlb.
HB13DISH is offline   Reply With Quote
The Following User Says Thank You to HB13DISH For This Useful Post:
Robbo (29-08-2008)
Old 25-08-2008   #5
My System: sky
i have got one
got a technisat conax dont need it as i am on a cs now after 25 gbp for it
laticsmon is offline   Reply With Quote
The Following User Says Thank You to laticsmon For This Useful Post:
Robbo (29-08-2008)
Old 26-08-2008   #6
Robbo's Avatar
Thanks guys, I think £25 would be too much as I could get a new one for £30
I'm also persuing a different option at the moment, trying to add a 2nd card reader, ripped out of my TM1000D+
Old 26-08-2008   #7
Sounds interesting idea Robbo. Please give details if it works, with pictures.
On the other hand, a bit risky especially on a new receiver.
Is it a 6800D or 6800HD?
Old 26-08-2008   #8
Robbo's Avatar
It's an HD.
Yes, a bit risky, had a bit of a shock yesterday, there are live mains bits in there.
Old 26-08-2008   #9
Atomicbullet's Avatar
My System: 90cm Motorised
Good luck!
Atomicbullet is offline   Reply With Quote
The Following User Says Thank You to Atomicbullet For This Useful Post:
Robbo (29-08-2008)
Old 26-08-2008   #10
trigger's Avatar
My System: 30W,7W,13E,16E,19E & 28E Dishes everywhere Darkbox 2008HD Sly+ V3
PM me and I´ll see what I can do
trigger is offline   Reply With Quote
The Following User Says Thank You to trigger For This Useful Post:
Robbo (29-08-2008)
Old 28-08-2008   #11
Robbo's Avatar
Bought one from Ebay for £15 now. Thanks for your input guys, as I wouldn't have know which one to get otherwise. I hope it works when I get it.
Old 28-08-2008   #12
I hope that it will work well, but I have my doubts in case it doesn't have the correct revision, which might be rather difficult to find out from e b a y.
Ref. Turok's post #2.
Old 28-08-2008   #13
Robbo's Avatar
Well, if it doesn't. I'll just re-flog it.
Old 29-08-2008   #14
Robbo's Avatar
It arrived today, works fine.
Has revision 4.0e on it.
Now got DigitAlb and Sky FTV inc CH4 HD, excellent.
Old 30-08-2008   #15
Good work
__________________
Give me it all....
Forum Jump
