The brackets really are quite simple, if your friend will make them for you he can use inch & a half or 2 inch angle iron which he may have or it will cost you less than a tenner at the metal scrap yard, it wants to be at least 5mm-10 mm thick and each bracket has 4 parts in a simple triangle.
Take a look at my picture, I made these myself... make sure you paint them in hammerite & don't get galvenised as he can't weld it.
My dish is a little different to yours as yours will sit above the top bracket.
You will also need to buy 2 u-bolts at the same diameter as your pole & ask him to drill holes for them near the end of the bracket, it's important that the pole is vertical 100% for a motorised system. |
