Amstrad DRX400 problemSky Digital support forum, for everything not included in the hardware and reception technical forum | |
| Member Join Date: 13-07-2008 Location: UK
My System: Amstrad DRX400 |
Hi all, new here, be gentle with me ![]() I have been given an Amstrad DRX400 which has been unused for some time. When I connect it to a (definately) working connection it comes up with a message "no satellite signal is being recieved". Im told this might be an easily fixable problem & NOT a fault...Any ideas? Thanx | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | First of all check the connections, make sure they are made properly. http://www.satellites.co.uk/satellit...91-post14.html You say it is a working connection, how do you know? | ||
| The Following User Says Thank You to rolfw For This Useful Post: | tiko789 (20-07-2008) |
My System: Amstrad DRX400 | Hi rolfw, I have a Panasonic receiver working on the connection at the moment. When I swap receivers (yes Im turning box off at the mains before disconnect/connect) & connect the Amstrad thats when I get the message "No Satellite signal" | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Yes, you may have a fault with the power supply that causes the no sat signal message or could be a connection fault as described. | ||
| The Following User Says Thank You to satelliteman For This Useful Post: | tiko789 (20-07-2008) |
| | #5 | ||
| Member Join Date: 15-04-2006 Location: Gran Canaria
My System: 3mtr Offset dish, 1.2m Dish Astra 1, 1m Dish Nilesat, 1m Dish Hotbird, Humax Freesat HDR, Cheap FTA Sat box, Quality AV. | Typical causes of this fault are - failure of one or more capacitors in the PSU or faulty tuner unit ( often caused by people doing up the f connector too tight and snapping the inner core in the tuner unit (as connector on box turns round). | ||
| The Following User Says Thank You to DishDick For This Useful Post: | tiko789 (20-07-2008) |
| | #7 | ||
| aka Skyman Join Date: 13-06-2003 Location: Limassol, Sunny Cyprus
My System: 3m(sky),1.8m(astr/hotbird),1m (nilesat)1m(arabsat)diseqc 4,sky plus,humax freesat,visionet 8000s,technomate 5400 ci+ usb super. Satlook nit colour + Horizon hdsm. wii ![]() | What if its on very old software? Have you tried upgrading it ? | ||
| | #8 | ||
| Specialist Contributor Join Date: 28-11-2004 Location: Lanzarote, Canary Islands
My System: 30W,7W,13E,16E,19E & 28E Dishes everywhere Darkbox 2008HD Sly+ V3 | Very unlikely but......... Check that that the default freq has not been changed. Seen it a few times where people change it when trying to add channels. Press Services 4 01 Select 2 Should be default to 11778. Use the red button to reset defaults and save. | ||
| amstrad, drx400, problem |
