Temporary Signal Loss at midnight!
Sky Digital support forum, for everything not included in the hardware and reception technical forum
Old 17-09-2008   #1
My System: Satellite: 1.8m dish with single LNB, standard Sky Thomson digibox. Computer: wireless network, 3 laptops - internet connection via Vodafone 3G
Dont know is this info helps:
I live in the Murcia region of Spain and I have a fair sized dish - 1.8m.
Signal is usually fine but over the last week I have noticed that the signal dies (and status says "Not Locked") around midnight. This stays true for around 30-40 mins, and then the signal returns and all is good!
It's been fine all year - only just started happening. I have absolutely no idea why! Maybe the theory of temporary power dips or satellite rotation times have something to do with it?
Anyway, that's my input!
Jon.
JONNY7469 is offline   Reply With Quote
Old 17-09-2008   #2
Amo Amas Amant Admin
Topper's Avatar
Hello
Welcome to the forum JONNY7469
I have removed your post from the 6 year old archive you posted your reply to. It is not a problem as your information is more up to date in view of all the changes in recent times.
Only a guess but we are coming up towards the equinox next month so battery backup power on the satellites may be creating the situation you describe. If it is then expect it to increase in duration for the next few weeks.
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 17-09-2008   #3
tomthebomb1968's Avatar
My System: Dreambox 800 Nabilo Blackhole v1.0/250 Gig/ Dreambox 500s-(clone) PLi Jade/ Relook 400s 160 Gig-/SifTeam 1.93 e enigma Foretec 90cm Dish with Nikkai Diseqc Motor- 2 sky+ receivers fixed 28.2 east.
Hi Jon, i cant offer any advice but maybe you could give me some. Are you anywhere near Campasol, in Mazarron. We are thinking of buying a villa there. Is it true you get a lot of bricks for your buck. A friend has one and i was supposed to go out for a fortnight to check the place over. My son took ill only 6 hours b4 the flight departed and we didnt get out. Is the 1.8m dish what I would need for continuous reception. Not sure what size my friends is but he says he looses signal around 10am Spanish time for an hour or two every day.
tomthebomb1968 is offline   Reply With Quote
Old 19-09-2008   #4
trigger's Avatar
My System: 30W,7W,13E,16E,19E & 28E Dishes everywhere Darkbox 2008HD Sly+ V3
Not sure topper but is the equinox not this month (I thought it was Sept 20th or so) probably wrong as always but never mind.
Cheers
trigger is offline   Reply With Quote
Old 20-09-2008   #5
Topper's Avatar
Yep
Hi tigger
yes you are correct, 22 September, so even more reason for me to be correct
Thanks for correcting me on that, I keep trying to forget the lunar calendar...even though my religion insists upon keeping to it
Show Your Support
Thank you.
Old 23-09-2008   #6
Former member
snap's Avatar
My System: Sky Plus V3 TDS 470n, Pace 2600CI, Thomson Sky HD, Technomate 1000D, Prodelin 1.8m dish + Invacom Quad C120, CM feed, Lacuna/Wolsey V3 meter
over the last week I have noticed that the signal dies (and status says "Not Locked") around midnight. .
This may be related to the equinox but in Astra 2 satellite terms this is 10th October, not now.
At this time of year, the satellites move into the earth's shadow near to midnight and batteries are switched on to preserve the signal, as the solar panels will receive no light. If you're familiar with astronomy, you'll know that the outer part is the penumbra. There is a time of day when the satellites in the Astra 2 group start to move into this shadow. This reduces the output very slightly (only noticeable on Astra 2D). When the batteries are fired up the signal returns to normal (higher than normal on 2D). You can see this happening if you have a good enough signal meter.
It's possible that this is what you are experiencing. Only a tiny drop in power can cause signal loss in fringe areas. If it clears up at the end of October, you'll be safe until March, when it'll happen again.
snap is offline   Reply With Quote
loss, midnight, signal, temporary
[IMG] code is Off
