How does the FreeSat from sky digital viewing card update?
Sky Digital support forum, for everything not included in the hardware and reception technical forum
Old 05-11-2008   #1
My System: DVBViewer and DVB-S
Does it update on a phone line?
Or by satellite?
I know it needs then "keep alive signal" every 4 or 6 weeks ... And is about to buy a Sky Box (Panasonic) with the card in and wanted to know when I'm from Denmark how to update the card...
It should be possible right? I think it is by satellite but needs someone to tell me.
Hoping for a Quick reply!
Best regards
//THUNDER
thunder2008 is offline   Reply With Quote
Old 05-11-2008   #2
Robbo's Avatar
Real name: Mark
Once activated, the card updates via satellite.
The activation process itself however, does require 2-way communication with Sky of some sort.
Old 05-11-2008   #3
Thank you so much...
The card is activated so that means that i can get it to Denmark and use the card and update it...?
Thank you for the answer!
Best regards
//THUNDER
Old 05-11-2008   #4
Robbo's Avatar
Real name: Mark
Yes, as long as you have sufficient signal on the necessary transponders. Search the forum for 'default transponders' for more detail, as this is something we don't have to worry about in the UK, as we get all transponders very easily.
Old 05-11-2008   #5
i have the transponders ... the only missing part is the card and receiver
Thank you for the quick answer!
Best regards
//THUNDER
card, digital, freesat, sky, update, viewing
[IMG] code is Off
