Silvercrest SL65 and Sky Mini Dish - Where are the TV Channels?
Old 16-11-2008   #1
My System: Sky Pay Once, Watch Forever. Silvercrest SL65 receiver.
(Apologies if this is NOT the right thread).
Got my heads around getting my 2-year old Silvercrest SL65 receiver to work with my newly installed SKY mini dish receiver.
The receiver is working but I can't seem to get any channels out of it. FYI, I have reconnected the wire to the back of the SL65 receiver from the Sky box.
I have around 700ish channels in the list but none of them are working (at least not the video ones).
Help/Advise welcomed/needed. What else do I need to do?
silicoonbits is offline   Reply With Quote
Old 17-11-2008   #2
Robbo's Avatar
Real name: Mark
You have it connected up wrong.
You have to connect the coax cable from the dish to the SL65 LNB input connector.
Old 17-11-2008   #3
Hi Robbo, thanks for the answer. I actually unscrewed the coaxial cable from the Sky box and reconnected it to the LNB in of the SL65.
Old 17-11-2008   #4
Robbo's Avatar
Real name: Mark
OOPs, sorry , misread.
What you need to do then, is select the 28E satellite in the installation menu, and perform a satellite scan. At least some of the TV channels should work after that.
channels, dish, mini, silvercrest, sky, sl65
[IMG] code is Off
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. Uptime monitoring by PageUtils.com
