Longevity of LNB's and Downlead Cables
Sky Digital support forum, for everything not included in the hardware and reception technical forum
Old 01-03-2009   #1
My System: Amstrad Sky Windows XP Home
Excuse my ignorance of such matters
Do LNB's and downlead cables ever give intermittent problems related to their age (in this case possibly getting close to 10 years) that are similar to the receivers themselves starting to fail (i.e pixelation and partial picture freezing on certain channels at certain times) or is this nearly always the box itself
Many thanks
Richard
Tembo11 is offline   Reply With Quote
Old 01-03-2009   #2
Site administrator
Analoguesat's Avatar
Yes lnb's can fail over many years, and whilst cables are normally reliable, they can fail if water get into them
(Due to a badly sealed connection connection or the cable chafing through)
Analogue forever!
Old 01-03-2009   #3
Many thanks for the reply
The F Plug cable connection at the external end still looks to have sufficient tape still sealing it. I think I may try a new LNB before I go down the route of replacing the box (even given that this is now a recon of an extra 5 years vintage)
Old 01-03-2009   #4
Amo Amas Amant Admin
Topper's Avatar
It should not have tape sealing it as tape will not seal it it should have self amalgamating tape which bonds with itself to form a solid rubber boot. That could be your problem
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 01-03-2009   #5
The set up has not been touched since a SKY engineer installed dish & cable quite a few years ago
Old 01-03-2009   #6
satelliteman's Avatar
Real name: Paul
Exactly, nail on the head.
I'd sooner check for dish alignment failing that swap the LNb and remake the connections.
Might be an idea to check with a friends receiver if you can or try yours on another dish.
satelliteman.
An Installers Choice
Follow us on
Old 02-03-2009   #7
What is the best way to check alignment for the dish for
N 53 31 02
W 1 44 02
that is according to my SAt NAv
Old 02-03-2009   #8
acezon's Avatar
My System: DreamBox 600s, Darkbox 2008, Liberty FTA reciever, Humax Foxsat HD, Thomson Sky+, 3 fixed dishes, 60cm for 13E + 19E, 80 cm motorised,Zone 1 sky+, BtVision and My 37" baby.
get your self a little sat meter a simple one that beeps so be enough to pin point the strongest position, you can get them from Ebay for next to nothing.
acezon is offline   Reply With Quote
Old 02-03-2009   #9
Design Engineer/Installer
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions...
you could use a small monitor/ tv on a long cable at the dish with the sky meter on screen... just concentrate on getting the quality bar as high as possible..
also... are there any trees that have grown up over the last few years or a neighbour who has had a new big aerial (or sky dish) fitted in that direction?
pedro2000uk is offline   Reply With Quote
cables, downlead, lnb, longevity
[IMG] code is Off
