Channel 5 problemsSky Digital support forum, for everything not included in the hardware and reception technical forum | |
| Member Join Date: 12-03-2009 Location: Mid Wales
My System: Technomate, 90cm dish |
Hi all, i have 2 sky digi boxes (using sky as FTA), downstairs box is showing on C5 "no sat signal is being recieved", however the box upstairs is absolutely fine and showing C5 and C5 US normaly, the feed is from a single lnb with two feed points (you know what i mean, im not familiar with exact tech. term, one cable is going downstairs and one upstairs its like multi-room i think), signal strenght downstairs is bit weaker than one upstairs.....????? any idea | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Unplug it from the wall, leave 5 minutes then plug it in again. There were a lot of reports yesterday of similar problems - I suspect the C5 channel mappings on the data stream were changed over from Astra 2C to Astra 2A yesterday | ||
My System: Technomate, 90cm dish | thanks for moving my post, i saw it there as other members had problems, thanks for the reply tho. strange thing, like i said one sky digi box is showing C5 and other can not find a signal, will try unplugin the box in question and see what happens. many thanks. | ||
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5ºN, 0.5ºW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | C5 + sister channels have been on 12422 (2A South) for at least a couple of weeks now. | ||
| | #5 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Lots of reports of Ch5 with 'no sat signal received'. A reboot or channel line up required. | ||
| | #6 | ||
| Member Join Date: 08-04-2009 Location: Suffolk UK
My System: Sky Pace box on communal feed. Computer: Linux Athlon 64 |
These channels disappeared from my setup on 26th March. Eventually someone from Sky admitted they had been having problems. If I use the "Add Channels" option and specify 12422H 27500 2/3 setup there is no incoming signal. I can get Five using the Freesat frequency setup of 10773H 22000 5/6, but it's a pain to switch on, particularly for recording. | ||
| | #7 | |||
| Regular Member Join Date: 07-11-2005 Location: Glasgow
My System: Passion HD, Nova HD S2, 85cm Mesh Dish, Fortec Star Diseqc Motor, Diablo CAM, Sky+ HD, Selfsat H10D2, Hauppauge HD PVR |
| | #8 | ||
Yes, I had Adams Aerials (who maintain the distribution network) to chec in March - they reported no problems, and on that day Five was coming in clearly. Since then, Five has disappeared or been visible only at night. I have emailed them again specifically about 12422H. Perhaps is was by pure chance that they checked on a day when reception was perfect (it even registered on the Signal Strength bar!) | ||
| channel, problems |
