Confirmation of a presumed Amstrad box tuner component faultSky Digital support forum, for everything not included in the hardware and reception technical forum | |
| Member Join Date: 13-11-2008 Location: Birmingham
My System: Amstrad Sky Windows XP Home |
At various different times and with various different groups of SKY channels I will get a group of succesive channels to give the eror messages "No signal being received" or "there is a fault with this channel" yet if I continue up the listing using the remote till I get a clear picure and then come back down the list, those same channels that were faulty just seconds before now seem to work correctly. I'm presuming this is the tuner section on it's way out rather than the LNB? | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Either the tuner or possibly the capacitors in the power supply unit. If its a really old Amstrad the best thing you can do it take it outside and drown it in a bucket of water! | ||
| amstrad, box, component, confirmation, fault, presumed, tuner |
