Sky Sports pack crippled...
Sky Digital support forum, for everything not included in the hardware and reception technical forum
Old 07-05-2009   #1
My System: Gibertini OP120 + Inverto Black Premium Twin @ 28.2E
I have the Sky sports pack. I get all the channels, SS1,2,3 and Skysports HD1 and Hd2. The puzzling thing is that I don't get the Sky Sports Xtra and the HD3.
For the SkySports Xtra I get a message that says I have to upgrade my subscription and for the HD3 that I have to upgrade to hd to get it.
I am a bit puzzled and I'd like to ask when you get the sports pack the channels are unlocked separately or as a whole pack?
Thank you.
w4tt4n4b3 is offline   Reply With Quote
Old 07-05-2009   #2
Young one with a hobby
Markjose's Avatar
My System: Motorised setup 68cm penta digit 45e - 30w
Speak to $ky about this little problem they should be able to help you.
Markjose is offline   Reply With Quote
Old 12-05-2009   #3
The thing is I can't speak to them directly...
Old 12-05-2009   #4
denis1501's Avatar
My System: 1.25m offset dish for Astra2 28deg., 1.2m dual feed for Astra1 and Hotbird, Thomson Sky HD, Humax HDCI2000, Dragon CAM, Invacom 0.3 twin lnb, Dell Dimension 4400 and Inspiron 1525, 1 meg broadband
How big is your dish? Sky Sports Xtra is on Astra 2A North which I believe is weak in Greece. Can you see Sky Sports News? Do you have problems viewing other channels that you subscribe to??
Which decoder do you have, the Thomson HD???
Sometimes if the decoder is receiving a very weak signal you will get the 'call to subscribe' or 'this programme is not available' message even though you are subscribed.
denis1501 is offline   Reply With Quote
Old 12-05-2009   #5
I have the Thomson HD Box...
Signal was checked with a device connected to the lnb. I get the Sky Sports News and all the other skysports channels but the skysports xtra and HD3.
My dish is 124.5x133.5 gibertini OP120...
Old 12-05-2009   #6
denis1501's Avatar
What happens if you go to 'add channels' and put in 12148, H???
Does your box find the channels or do you get a 'no signal' message????
Old 12-05-2009   #7
I think I tried it and I got a message that there are no channels at that frequency. While at the 12070H it did find the Skysports Xtra.
We checked with a device connected to the lnb the signal for 12148H and there was a message no channels at that frequency found on the screen of the device.
For the 12070H the signal was ok...
Old 12-05-2009   #8
denis1501's Avatar
The Sky Sports Xtra at 12070 H is for pubs only. You can not view with a normal sky sub.
The one you require is on 12148, H along with Hallmark UK, British Eurosport 2 and Comedy Central Extra to name a few.
Can you see these channels????
The Following User Says Thank You to denis1501 For This Useful Post:
w4tt4n4b3 (12-05-2009)
Old 12-05-2009   #9
Ι added the 12148H, 2/3, 27500 and I get a left column with the following channels,
Sky Spts News
SP news
Sky Spts News
Sky Spts News
Sky Sports 1
Eurosport2 UK
Hallmark
S1 test
Sky Spts Xtra
Sky Spts Xtra
ComedyCtraIX
and there is one right column with Sky Spts Xtra only
Can I upload a screen shot?
I can see Eurosport 2 UK, Sky Sports 1, Sky sports news. The hallmark and the comedy I am not sure they are in my package but I will look for them in the tv guide of the box to see if I can get them...
Edit no2: Hallmark is not in the packages I have so I get a message that I have to upgrade my subscription to receive this channel.
Sky Sports pack crippled...-image_0512-1138-component-jpg
Old 12-05-2009   #10
denis1501's Avatar
Well that proves that it's not a signal problem that you have anyway. Save all the versions of Sky Sports Xtra by ticking each one with the yellow button, then press select to save them to your other channels. Now go to your 'other channels' menu and see if you can view any of them.
Old 12-05-2009   #11
I highlighted the Sky Spts Xtra (they were listed 3 times in the add channel list) and pressed the yellow button each time (they were ticked) and then select.
I went to Other channels and I found Sky Spts Xtra 3 times.
I pressed select and I get the message "Programme synopsis is not available. Call your broadcaster to upgrade your subscription to receive this channel".
Sky Sports pack crippled...-image_0512-1219-component-jpg   Sky Sports pack crippled...-image_0512-1218-component-jpg
Old 12-05-2009   #12
denis1501's Avatar
Crikey, that's weird!
I take it you've already tried re-booting the box from the mains?
Can't think of anything else right now except maybe a faulty box. Hopefully some expert can come on here and help you out!
regards
D.
Old 12-05-2009   #13
I have already done a system reset via the hidden menu.
Is yours a different one?
When you say faulty box in what sense?
That is the message I get when I try to select the channel from the sky listings...
In any case thank you denis for your help...
Sky Sports pack crippled...-image_0512-1246-component-jpg
Old 12-05-2009   #14
denis1501's Avatar
I didn't really mean a system reset, just wanted you to try plugging the box out from the mains and then plug it in again. Also maybe remove the viewing card and clean the contacts.
I also have a Thomson HD with upgraded psu and a 500gb wd hard drive. But this problem you have is different to any I've seen before!
Sorry I couldn't help you bud, I really hope you find the solution. Maybe you need the activation signal re-sent from Sky?
Old 12-05-2009   #15
I did unplug it from the mains.
I fear that a signal resent may be necessary. and the problem is there is no one to ask for it or manage the whole situation...
Old 12-05-2009   #16
Well card was removed before the new card (white) got in...
How do you clean the contacts? What do you mean by cleaning the contacts?
Old 12-05-2009   #17
Amo Amas Amant Admin
Topper's Avatar
Well
Simply wipe a dry non magnetic cloth over the contacts on the chip to ensure no grease is stopping connection with the contact arms
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
The Following User Says Thank You to Topper For This Useful Post:
Old 12-05-2009   #18
Thank you, Topper
Well, the card is less than one month old (came new stuck on the S k y paper) and the problem with Sky sports Xtra and hd3 was from the beginning of the pairing.
I don't think this is the problem but I will give it a try.
Old 12-05-2009   #19
trigger's Avatar
My System: 30W,7W,13E,16E,19E & 28E Dishes everywhere Darkbox 2008HD Sly+ V3
Why can´t you contact them? I ask as there should be a work around.
I think a refresh from sly should sort it but I have seen similar problems before and can take a few calls
trigger is offline   Reply With Quote
Old 12-05-2009   #20
I can't contact them because I am outside the UK...
Old 12-05-2009   #21
trigger's Avatar
Have you got Skype on your computer? If not get it and phone them using that. It is a bit expensive to phone sly - compared to skype´s usual low prices - so make sure your topped up first. They won´´t know where your phoning from and tell them your problem.
Good luck
Old 12-05-2009   #22
The thing is that I have only the card number, box and name of the subscriber. No other data...
Old 12-05-2009   #23
trigger's Avatar
Ok I understand. So If the card came stuck on the paper then the details should be on this paper. If not and it came thru an agent then they should contact them.
If its only a month old then how did you get the card paired to the box?
Old 12-05-2009   #24
I did not pair them. The agent is nowhere to be found since 2 weeks time...
There was no contract booklet. All new white cards come with a paper that has no contract details just refers to the old card number that it replaces...
Old 12-05-2009   #25
trigger's Avatar
The paper you got would have had the full details on it. The agent has removed the relevant details.
OK Keep trying the agent but have heard one of the big ones in Spain has "gone"
crippled, pack, sky, sports
[IMG] code is Off
