Sky 1HD and Nat Geo HD
Sky Digital support forum, for everything not included in the hardware and reception technical forum
Old 29-08-2009   #1
Dream-Believer
newgen2005's Avatar
My System: Dreambox 500s, gemini v3.30 80cm dish 1.0w
I have had my Pace Sky+HD box (2 feeds) for about 2 months and I am having problems with some HD channels. Sometimes these 2 channels breakup and become pixelated as if the signal is weak! the strange thing is that the standard def Sky 1 and all of ther other channels are fine! Though it doesn't do it all the time, usually in the morning or late at night!!
I live in a flat and we have the feed box in our loft, this has recently been upgraded to a bigger one due to us wanting an extra feed in the bedroom for Freesat.
To be honest I did a bit of d.i.y for the second feed, I used the existing coax cable and used a coax to sat connecter and joined a new piece of sat cable to the end of the coax in the loft and connected that to a spare feed on the box. Worked fine got my 2 feeds, can record without any issues. Would the pixelation be something to do with my handy work on the second feed or is the dish getting tired?
Any advice would be welcome.
newgen2005 is offline   Reply With Quote
Old 29-08-2009   #2
Toute Ronde Bon Oeuf
Tivù's Avatar
Real name: Gordon
Joins should be avoided where possible as they can not only provide a weak point for interference, but they can also cause unpredictable effects at some frequencies, particularly if the cable sections are not identical in construction.
Tivù is online now   Reply With Quote
Old 29-08-2009   #3
Site administrator
Analoguesat's Avatar
Could be any one of half a dozen reasons
the dish may have moved slightly
the cables may be damaged
the cables could be full of water
there could be local interference
the joins in the cable could be causing impedance mismatches
etc etc
Analogue forever!
Old 29-08-2009   #4
Dream-Believer
newgen2005's Avatar
Thanks for the advice guys.
Let’s say my join is causing the issue, wouldn't this effect all channels? why just HD channels?
A neighbour had an issue with the music channel 'the vault' the engineer came out and checked the dish, this was all OK and turned out it was her cordless phone that was causing the pixilation due to interference from the phone!
So it looks like it might be my join then! I do remember having job getting the sky connecter on the end of the coax as the coax appeared to be thicker so I had to really force it on!! The length of cable between the feed box in the loft and the join should be OK as this was already made up. The joiners and connectors I got from B&Q, maybe I need a connector that is bigger to allow for the coax thickness?
Silly question but is it possible to have connected it to the wrong place on the feed box?
If I take some pictures of my setup, could you guys have a look?
Cheers
Old 29-08-2009   #5
Dream-Believer
newgen2005's Avatar
Here is some pictures, it does look as if the signal is very poor though!!
http://img42.imageshack.us/img42/1220/64992803.jpg
http://img42.imageshack.us/img42/461/43057873.jpg
http://img198.imageshack.us/img198/8039/83439096.jpg
http://img20.imageshack.us/img20/2268/69531543.jpg
http://img42.imageshack.us/img42/2408/11796238.jpg
Old 29-08-2009   #6
Manic Midlander Moderator
nanochickin's Avatar
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription
Excuse me while i stop laughing
Whoever installed that switch is breaking every regulation in the book
There is no earth bonding anywhere from what i can see. That system should be switched off until the earthing issue is resolved.
Its also not very neat is it? If i did work like that i would be on the dole now
You will need to run a cable straight from one of the unused outputs with no joins using good quality CT100. You can connect it to any of the feeds numbered 1-12.
By the way the cable you are using is probably one of the main causes
Fit a new run of cable from the switch to the receiver and come back to us. I would also mention to your landlord that the system has to be earthed by law
You want it to look like the one i did earlier in the picture below
Not one of my neatest but at least its got the all important earth bonding
Nano
Sky 1HD and Nat Geo HD-mgheadend-jpg
Sanity is nothing more than an excuse to be boring
<<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>>
<<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>>
<<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>>
nanochickin is online now   Reply With Quote
Old 29-08-2009   #7
Dream-Believer
newgen2005's Avatar
Nano
Oh OK, I will get the earthing checked out. So much for qualified installers!! I only did the join myself as the installers take forever to show up!! I am not an engineer so could you explain about the earthing issue?
Old 29-08-2009   #8
Tivù's Avatar
Real name: Gordon
I'm in the process of drafting a mini-tutorial on Earthing and Bonding and why the term "Earth Bonding" is misleading. Owing to other commitments, it'll be a day or three yet!
But you're right: Suffice it to say that anyone installing systems like yours should be competent not only to understand what Earthing and Bonding is and how to implement it, but should actually do it!
1hd, geo, nat, sky
[IMG] code is Off
