two TV links one TV?Sky Digital support forum, for everything not included in the hardware and reception technical forum | |
| Member Join Date: 19-11-2008 Location: Essex
My System: Usenet, WDTV, and a TV |
I want to put two seperate tv links to the same tv, can I just use a Y-Piece splitter? Or is there a better alternative? Couldn't decidede if this should sit here or in the $ky section, so feel free to move... and just realised I've posted not even in the forum I intended to, so please move. | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Not sure what you're trying to do, control two digiboxes? PS. Sorry missed this in the AV section, so moved to here. | ||
| Specialist Contributor Join Date: 06-09-2008 Location: Sunny Scunny
My System: Motorised ASC 1.2m,1224 Supermount with C120 Invacom Quad LNB with Matched Feedhorn. | If your not fussed about using magic eyes you can loop all your boxes together via rf leads each box needs setting onto it's own clear rf output frequency after they are looped together run an rf2 feed from the final receiver to the desired tv destination. If on the other hand you want to be able to control each box individually I'd recommend the use of a global supercombiner it's a case of running an rf2 run from each receiver into the combiner inputs, the signals exit the combiner via it's one output, this can also be distributed via a bypass amp and distributed around the home once again each receiver needs it's own clear rf output frequency setting and then boxes can be tuned into channels 6,7 and 8 if you go for all 3 skyboxes | ||
| The Following User Says Thank You to kenny1234 For This Useful Post: | image (23-09-2009) |
| links |
