Detecting the LNB feed typeSky Digital support forum, for everything not included in the hardware and reception technical forum | |
| Member Join Date: 16-09-2009 Location: London
My System: Samsung Sky+ HD box |
Hi, I want a method to easily detect whether the LNB feed into my apartment is single or dual. Is there a way to do this? I have a Sky+ HD box. Thanks | ||
| | #2 | |||
| lifes not a practice run Join Date: 27-09-2006 Location: torfaen south wales
My System: Technomate diseq 1500ci+ and Humax Foxsat HD Acer Aspire 5315 |
regards Dave | |||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Not quite sure what you are asking. If there is a single "F" connector outlet, then it will be a single feed, if there are two "F" connector outlets, then connect both and see if both tuners show signal strength and quality. If it is only a single connector and you require two, then you need to check with the management company whether there is any redundancy at the head end for an extra feed. | ||
| | #4 | |||
| Toute Ronde Bon Oeuf Real name: Gordon Join Date: 29-05-2009 Location: North Yorks Moors
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. |
Even if there are two, they may not be both connected. In which case, you'd just have to check, using your Box. PS: Both of us who have replied so far appear to have interpreted your question quite differently? I'm not sure who is right - if either of us! PPS: Posted a microsecond after rolfw, who sees it the same way as I. | |||
| | #5 | ||
My System: Samsung Sky+ HD box | Thanks for the resposes. There is only one F-socket into the apartment. I wasn't sure if when the guys at Sky said I needed dual feed for Sky Plus to work properly that meant two seperate cables or a single cable that could carry two signals. I guess it means I need two seperate cables coming into the apartment from the dish. So it looks like I'm out of luck! Thanks | ||
| | #6 | ||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | Two cables required. Common problem in Apartment Blocks, I'm afraid | ||
| | #7 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | It is possible to have a second feed down a single cable, but you need to check on the redundancy at the headend. If there is a spare output, you can use a Stacker/De-Stacker to supply the extra feed, or a Single cable router, although this is generally a more expensive option, it can be used when there is not a redundant/spare feed. | ||
| detecting, feed, lnb, type |
