RTE In the UK - Can you help?
Sky Digital support forum, for everything not included in the hardware and reception technical forum
Old 25-01-2008   #51
My System: Broadband
Should be ok- like I said- My irish address (also my parents) can be spelt 2 different ways (its a townland in the country side). Will sky twig that it's the same place- even though the spelliing is slightly different?
piggs is offline   Reply With Quote
Old 26-01-2008   #52
My System: Sky+ TDS470N 160gb
As I said piggs, just add an A to the number. Like, 12 Rivercourt becomes 12A Rivercourt. That is fine. Also, don't call Sky, email them. When you call them they try their hardest to talk you out of anything that doesn't involve them charging you. Remember, you are self installing when you "move" to Ireland - they don't like this because they won't be charging you for a House Move.
benifa is offline   Reply With Quote
Old 26-01-2008   #53
I wont be able to add an A to my address- my house in Ireland has no number- the postman simply knows which family lives in which house! Has this method of changing address worked? Do you know anyone whos tried it?
Old 26-01-2008   #54
john_graydon's Avatar
My System: Dusty Dreambox 7000s, & Sky HD.
Originally Posted by denis1501 View Post
To answer the first part of your post, no, there will be no problems providing the digibox being used by your mother is not subsidised, ie you don't get it free from sky. Reason being if it's subsidised it has to be connected to an Irish phone line for 12 months.
Part 2 of your question, No, no chance of taking a multiroom box, these MUST be connected to an Irish phone line at all times.
regards
D.
They are charging the full price for second boxes not detected with phone line, instead of cutting them off. I tried the 9v battery trick and it dont fool them after so many months engaged. They are cracking down hard on this the last 12 mts.
Happy Dreaming
john_graydon is offline   Reply With Quote
Old 26-01-2008   #55
Hi Ian,
There is a way to do this.
Ring Sky and tell them to send you out a contract to your Dublin address telling them that you have an 'out of contract' box already in your possession and don't require an installation.Fill out the contract and send it back.
When you get your card take note of the number and send it to your Dad in Manchester.
Tell your Dad to go into the Services menu of his digibox and write down very carefully the serial number of his box and version number. Then ring Sky from Ireland and tell them you have received your card and require it to be activated. Make sure your Dad knows what time you're ringing Sky so that the card is in the digibox and ready to receive the over the air activation.
The Sky representative will take the box and card details and the card will be activated!
Your Dad will be watching the GAA in no time!
regards
D.
Does anyone know- can this still be done now?
Old 03-02-2008   #56
My System: Cable but Fortec Star dish and Technomate receiver
But when sky are installing at my UK address- will they not insist on connecting the system to a phone line? How do I avoid that?
Hi, Just inquiring if you managed to successfully get RTE via the sky route described by benifa?
benignb is offline   Reply With Quote
Old 15-02-2009   #57
My System: sky p4, dual 3ghz, 2gb,
I don't know if this helps but try manually installing the irish channels on your sky box
10744 H 5/6
signman is offline   Reply With Quote
Old 15-02-2009   #58
Dazed and Confused Mod
PaulR's Avatar
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100
Won't work unfortunately as the chnnels are encrypted and are not viewable without a valid up-to-date Irish $ly cubscription card.
With the card there will be no need to go into the "add channels" as they will appear in the EPG.
As I get older I find myself thinking about the hereafter - I go into a room and then wonder what I'm here after.
PaulR is offline   Reply With Quote
Old 21-04-2009   #59
My System: Pace Sky Digibox
Hi Ian,
regards
D.
To repeat pigg's question, can this still be done? It sounds like the most accurate way to get RTE in the UK. Thanks guys!
obried26 is offline   Reply With Quote
Old 22-04-2009   #60
Yes it can.
Old 09-06-2009   #61
My System: Sky + HD
UTV & RTE in the UK
Hi benifa,
Your solution seems by far and away the most efficient on here. I have a couple of questions.
Can I use your solution with an address in Northern Ireland? That way I get RTE and UTV (both carry GAA coverage) and my account will stay in £ sterling.
I have a HD box with the HD subscription, will this still work ok?
Finally, I seen ads on the TV saying SKY are issuing new viewing cards and a new EPG setup. Will this scupper my plans?
The address I plan to use is my parents which doesn't have sky installed at the moment but I plan to do the "A" suffix anyway.
hughes_jh is offline   Reply With Quote
Old 10-06-2009   #62
Originally Posted by hughes_jh View Post
Hi benifa,
Should be fine. You're in England, the address of your Sky account is to be one in NI - your parents address, right?
If so, shouldn't be a problem at all. And I agree - an NI sub is the best of all!
rte
[IMG] code is Off
Similar Threads
RTÉ, BT and RadioScape team up for live mobile TV Satdude Tech Head News Items 1 09-02-2008 05:21 AM
RTE begins license fee crackdown net1 Daily Satellite and Broadcast industry News 0 22-09-2003 08:52 PM
Sky, RTÉ sign new Irish football deal net1 Sky Digital (BSkyB) and Astra 28.2 East General 2 27-05-2003 10:18 AM
Rte, Bbc & Itv On Astra 2 In Turkey!!!! ronan1211 Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 1 25-05-2003 09:39 PM
RTÉ agrees to stay on Sky net1 Sky Digital (BSkyB) and Astra 28.2 East General 0 02-05-2003 05:40 PM
