Mesh or Solid Dishes
Sky Digital support forum, for everything not included in the hardware and reception technical forum
Old 10-08-2003   #1
neil mcclary
Posts: n/a
Talking Mesh or Solid Dishes
Mesh or solid, is one better than the other or are they about the same when it comes to performance.
Old 10-08-2003   #2
iceman's Avatar
My System: 3.0m Motorised Channel Master 4 fixed dish SKY_HD DM7020s Vsat Kathrein UFS-910 HD
How can they be same when mesh dish has so much less reflector surface (because of the holes) than solid dish?
Definately solid dish is allways better...
Large mesh prime dishes are mainly used for C-Band reception.
iceman
iceman is offline   Reply With Quote
Old 10-08-2003   #3
neil mcclary
Posts: n/a
many thanks
Old 11-08-2003   #4
Dazed and Confused Mod
PaulR's Avatar
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100
Sorry, but I disagree.
If the holes in the mesh are smaller than 1/2 a wavelength then the incoming signal will "see" a solid dish. If a solid dish and a mesh dish were made from the same perss there would be no difference in signal gathering efficiency.
A mesh dish better on 2 grounds. It is less visually obtrusive (all right - only slightly) and when it is windy it will not put as much strain on the mounting pole and bracket.
BTW, this explains why you shouldn't use a C band dish on Ku band. The C band mesh is spaced much wider than for Ku band. As far as the Ku band signals are concerned the dish is practically not there!
PaulR is online now   Reply With Quote
Old 11-08-2003   #5
iceman's Avatar
mesh vs solid dish
Date: Sun, 10 Oct 1999 15:06:28 +0200
"Rafael P. Sandoval" wrote:
For a given frequency in the Ku band, for the reception of TV signals, is a solid dish better than a mesh dish? If so, please explain. Also I know that the "holes" in a mesh could affect the reception of signals in either the C or Ku bands. If this is so, why are there mesh dishes?
Thank you and best regards,
Dr.Dish:
A accurate made mesh-dish delivers in ku-band a signal strength with the factor of 0.8, compared to a accurate made solid dish. This means you can compare a 3m mesh-dish with 2.4m solid dish. Much better is a double-mesh antenna. The holes are small enough to reflect a ku-band signal without too much losses, but still is not very strong to keep always a perfect parabolic shape (wind/change of temperatures). On the other hand, a strong and accurate made mesh dish will survive easier the full load of a storm. The mesh is a relict out of the old c-band age and works fine on this frequency-range.
-- Christian Mass (Dr.Dish)™
© 1999 by Dr.Dish
copy pasted from http://www.drdish.com/knowledge/9910/991003.shtml
iceman
Old 13-08-2003   #6
aka Skyman
Zorba's Avatar
My System: 3m(sky),1.8m(astr/hotbird),1m (nilesat)1m(arabsat)diseqc 4,sky plus,humax freesat,visionet 8000s,technomate 5400 ci+ usb super. Satlook nit colour + Horizon hdsm. wii
You shold see the big mesh dishes down along the seafront here.The older ones look like skeletons because the wind has ripped of the mesh.Probably get a bit torn from hailstones etc and the strong winds do the rest.and they rust quickly because the frames and struts are all hollow tubing,which is why they are light,which is why they move a lot in strong winds.
Zorba is offline   Reply With Quote
Old 14-08-2003   #7
Mod and septic resident
Channel Hopper's Avatar
@neil
Depends on your location, how much you initially want to pay, what you wish to watch,(and on what frequency), how often you are prepared to pay for servicing / repair/ replacement, and whether the neighbours would notice a 7m mesh thing, or a 5m solid one
For me, solid wins every time
Old 01-09-2003   #8
RogerP's Avatar
Dont know about yours, but my microwave oven has a mesh reflective surface on the door and (hopefully) all of the waves are reflected!!
RogerP is offline   Reply With Quote
Old 01-09-2003   #9
robbins1940
Posts: n/a
Solid is better. When it snows all the minidishes are covered in snow where as my channel master 1.2m dish is only partly covered in snow and can still get a signal from astra 2 slot.
On mesh dishes the snow blocks up the holes in the mesh reducing the signal and hence no picture and since the dish is so small you will lose picture altogether the slightest hint of any bad weather.
David
dishes, mesh, solid
[IMG] code is Off
Similar Threads
mesh vs solid dishes Simba27 Einstein's Alcove 29 12-07-2006 04:54 PM
Dish Choice - Mesh or Solid, which is best? Markie9999 DISH SETUP: Single sat, Multi-Sat & Motorised systems 4 04-12-2004 07:42 AM
Two dishes over a single cable? Martie Multi-receiver/TV systems - Domestic only 6 18-11-2004 07:24 PM
Dishes sailor Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 6 30-06-2003 01:12 AM
Solid Vs mesh Robbiewright Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 4 23-02-2003 12:14 PM
