used digiboxesSky Digital support forum, for everything not included in the hardware and reception technical forum | |
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ |
hi can anyone recommend a online place to buy a used digbox as i'm after something decent like a pace ds430n i've seen them on Ebay theres a seller on Ebay has anyone used them before as they say to offer 3 month garantee with them ? what are the new sky digiboxes like ? are they decent but i dont like the design as you cant stack them and heard about faults with them thanks wod | ||
| Specialist Contributor Join Date: 05-04-2005 Location: Midlands UK
My System: Skymaster DCI9900 + PC/twinhan combination. 80cm dish. GBPVR with 2 DTTV cards +hauppauge Media MVP | Car boot season around the corner....should be loads going spare now peeps have had chance to go S_y+ and HD | ||
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | ended up buying one off Ebay its very quick compared to my pace 2500s5 also could someone let me know what the latest software version for a pace ds430n is please thanks wod | ||
| | #4 | |||
| Guest
Posts: n/a
| Kool did you get a FTA card with it, Best thing to do is do a sofware update by unpluging the box then hold back up on the front of the receiver while pluging it back in untill all the lights come on and you get a update message on the screen, How much did you pay for it,
| | #5 | ||
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | no fta card as already have sky so just used that card which worked fine probably over paid but offered 50 notes for one as the seller states a 3month warranty as i bid on a few of them and they went over 40 pound so thought the price i paid was ok might use it and loop it through my motorised dish | ||
| | #6 | ||
| Specialist Contributor Join Date: 23-07-2005 Location: S.Wales
My System: 1.2M, & 55cm Gregorian Dish`s, 1.8m Precision dish Jaeger 1224 H-H motor.Dreambox 800, Vbox-II. SS2 Card. | Its a nice looking digi box, but appart from that what`s so speacial about this stb? | ||
| | #7 | ||
| Guest
Posts: n/a
| the white pace ones are the best the ds430n is good and the 2600c1 that looks the same just the 2600c1 has a sharp made tuner so it's better for fringe areas like spain etc, Best way to pick them up cheap is on Ebay | ||
| | #8 | ||
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | seems the holding backup then plug in doesn't seem to work as i can get the lights on the front lit up but no update message Can anyone who has one let me know the software version and epg version as its missing some channels in the epg | ||
| | #9 | ||
| Guest
Posts: n/a
| | #10 | ||
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | updated it twice but no joy so i guess theres no update for pace ds430n | ||
| | #11 | ||
| Regular Member Join Date: 08-12-2005 Location: hastings , uk
My System: Technomate 1500ci + super , motorised 90cm triax , sky freesat uk | The latest EPG version for single tuner sky boxes is 3.4.4b or 3.5.3 both being the same , the latter one adding a ,, system healthcheck '' which i think it's done over the phone line anyway . Hope this helps . | ||
| digiboxes |
