Brand new box problem
Sky Digital support forum, for everything not included in the hardware and reception technical forum
Old 25-02-2004   #1
bollywood's Avatar
Post Brand new box problem
Last year i brought some Panasonic & Sony boxes of some guy brand new boxed some of the boxes i sold i had no complaints
Today i was going to sell a Panasonic TUDSB31 to a m8 so i thought i would show him how to do a software upgrade
the problem is when i power up the box. after 25secs the box goes into standby
i have tried it couple of times same problem anyone know why it does that
its a brand new box & was never connected
bollywood is offline   Reply With Quote
Old 25-02-2004   #2
rolfw's Avatar
Real name: Rolf
Don't think that there is anything you can do without opening the case, it isn't unknown for receivers to be dead on arrival. Bear in mind also that this receiver is several years old, even though it hasn't been used, some components do not improve with long periods of storage, I believe that capacitors fall into this catagory and form an essential part of the power supply.
Rolf
Old 25-02-2004   #3
Super Minty Mod
PoloMint's Avatar
My System: 1200cc with 100,000,000,000 neurons and 100,000,000,000,000 connections
Some Panasonic 31s shipped with faulty power supplies, they went wrong very quickly, the initial symptoms of it being bad blockines on some channels and eventually in some cases unable to power up.
PoloMint is offline   Reply With Quote
Old 25-02-2004   #4
Hmm, now what seems to be the problem?
dishdoctor's Avatar
A forced software update usually fixes this,see if the receiver stays on longer than 25 secs while updating software.........brian
dishdoctor is offline   Reply With Quote
Old 25-02-2004   #5
bollywood's Avatar
Angry
When updating the software it takes between 10-15mins once it done that it on standby. i turn it on (green light) after 25secs it back to standby
Old 26-02-2004   #6
dishdoctor's Avatar
During the 25 seconds is there enough time to read the system details menu to see if a update has taken place.....try this...hold the back up button on the digibox in as you unplug the mains,keeping the button pressed,reconnect and update again.....what have you got to loose.......brian
Old 26-02-2004   #7
bollywood's Avatar
Angry
The software iam getting is 27a7* after following the above info the problem is still the same. but now when i press Service and 5 then 6 i am taken into the favourite menu. it say seaching channels then the box goes off
Old 27-02-2004   #8
dishdoctor's Avatar
The software has not updated.Are you in the uk?,The software should read 3.1a5 or maybe 3.1a6...until you update it the digibox will not work correctly if at all...brian
Old 27-02-2004   #9
bollywood's Avatar
Angry
I have double checked the software it is 2.7a 2* i am in Buckinghamshire UK i have tried over 10 times to upgrade the box but no luck is there anything else i can try if not it looks like it going to end up on Ebay
Old 27-02-2004   #10
rolfw's Avatar
Real name: Rolf
Whereabouts in Bucks Bollywood, if you can't manage to get the upgrade sorted, it may be worthwhile taking or sending it over to Horizon at Basingstoke, they can repair it for you.
Rolf
Old 28-02-2004   #11
bollywood's Avatar
Post
I am in Marlow i will try them. do you know how much i can get for it if i sell it like this. as the guy i wanted to sell it to as taken another working box of me
Old 28-02-2004   #12
rolfw's Avatar
Real name: Rolf
Don't bother trying to sell a faulty box, you will get next to nothing for it, may as well bite the bullet and get it repaired. You can post it to them if you dion't want to drive over there.
Rolf
Old 28-02-2004   #13
dishdoctor's Avatar
A dsb 31 has an Ebay value of about 40/50 pounds,a simple repair including two way p@p is going to cost at least 40 pounds,if it really was a brand new box,then if you could try on another dish to update,unlikely but still worth a try,it is not unusual for the update to fail,but a good sign is that it completes the update cycle and switches off after approx 10 minutes.This happened to me,failure to update after three attempts,holding back up before unplugging and replugging worked after a further 3 attempts......percy vere mon poppadom....thats latin you know.........brian
Old 28-02-2004   #14
dishdoctor's Avatar
Just a thought,during the 25 seconds the box is on do you get any channels,like sky news or bbc,you did mention searching for channels so perhaps not.Turn the digibox on,press Services,4,0,1,Select to enter engineers menu,choose Lnb options,the 4 boxes should read 9.75....10.60....ON....ON....if this is not correct the box will not update..............duet et mon droit....sacret bleu.........brian
Old 28-02-2004   #15
bollywood's Avatar
when i press service 4,0,1, all i get is picture setting menu sometimes i get less then 25secs box goes of i have a 1metre motor dish so i think the signal should be good. i take it to my brothers house and try it there
Old 28-02-2004   #16
dishdoctor's Avatar
Press......Services......4......0......1......sele ct........thats 5 pushes......brian
Old 28-02-2004   #17
bollywood's Avatar
it comes up as
9.75
10.60
ON
ON
Old 02-03-2004   #18
digidude's Avatar
My System: loads of stuff, i'll get round to listing it all
i know im a newbie to this forum but, by connecting it to a 1M dish you are also picking up extra 'noise'. connect the box to a friends normal minidish and try the update, also try keeping the box somewhere cool (we used to find that you could get further from a customers house first thing in the morning when boxes in the van were cold before they packed in) for a few hours before trying
hope it helps digidude
digidude is offline   Reply With Quote
Old 02-03-2004   #19
bollywood's Avatar
thanks i try that
Old 04-03-2004   #20
sting's Avatar
if u take the cable form the lnb on the dish out the back off the box then switch it on then try menu 4 0 1 select. it will stay on. but another thing is that irs ur lmb if it's a very very new'sh l m b thats wot would be wrong i actyall install satellie's 4 a living so dont slag me off too early
sting is offline   Reply With Quote
Old 04-03-2004   #21
digidude's Avatar
when you say the box goes off does it die completely or reset itself. it sounds like it may possibly be a faulty capacitor in the power supply
My Linux boxes: DM800, DM600, DM7020Si x2, DM500 x3, TM600 x2, TM500 x2, TM9100Super, TM9100
My STBs : TM1000, TM1500, TM5200Super, TM5300, TM3150, TM3500, TM3300, TM6900, TM6800Super, TM6900Super
My dishes : 1.1M solid TM2300 motor TM4 0.1dB quad LNB, 8, 2x 80cm mesh TM2200 motor quad LNB, 80cm mesh TM2100 motor TM1 0.1dB LNB, 60cm mesh fixed @ 28.2E with quad LNB
I dont watch TV
Old 04-03-2004   #22
bollywood's Avatar
The box goes onto standby
Old 04-03-2004   #23
digidude's Avatar
i'll find out what cap needs changing for you. how are you with a soldering iron?
I dont watch TV
Old 07-03-2004   #24
bollywood's Avatar
Thumbs up
I took the box to by brothers house and tried it there within 10mins i had the lastest software averything is working ok now
I like to thank averyone who help me solve this problem
Old 07-03-2004   #25
digidude's Avatar
glad to help m8, if you need a normal digidish then mail me, you pay the postage and its yours
digidude@euro-sky.co.uk
I dont watch TV
box, brand, problem
[IMG] code is Off
Similar Threads
Free-xtv Update Sky Box Not Responding ars1604 Receiver software, international Section 17 07-01-2005 09:19 AM
Sky Active Connection Problem Colinsav Sky Digital (BSkyB) and Astra 28.2 East General 0 16-12-2003 03:36 PM
Pioneer to launch Freeview digital set-top box net1 Terrestrial Television, Digital and Analogue 0 08-08-2003 10:44 PM
Netgem launches I-Player DTT box in Spain net1 Daily Satellite and Broadcast industry News 0 30-06-2003 08:32 PM
Sky Box Office price hike. net1 Sky Digital (BSkyB) and Astra 28.2 East General 0 25-06-2003 09:18 PM
