Can someone try this
If you use an Irish Subscription so you get setanta Ireland and setanta 1 & 2 Irish versions.
Remove the card and reboot the box. It now should be a uk box (BBC London on 101) then select setanta sports and then reinsert the irish card. The card will open setanta but the UK versions. This does work.
Can someone with a setanta subscription try this the other way around.
Power a box with an Irish card in it so that RTE is on Ch 101. Select setanta Ireland and then insert a UK card with a UK setanta subscription. Does it open setanta Ireland and the Irish versions of 1 & 2? |
